Pocket GPS World :: View topic - Printing using MemoryMap
Pazza
PostPosted: Thu Apr 29, 2004 9:19 pm    Post subject: Printing using MemoryMap Reply with quote
There seems to be a problem printing the maps with or without routes etc. The print seems normal as far as the Print Preview but the print out has random what looks like overprinting which may cover the whole print or just a band say 5cm wide. The map is unreadable but the rivers, roads and other areas such as woods together with the names are readable with the rest rubbish which varies from almost opaque to lines with what look like extended blocks down from the lines. I have tried reloading and but no luck and it appears to happen with the old and updated version. Any ideas?
lbendlin
PostPosted: Thu Apr 29, 2004 9:35 pm    Post subject: Reply with quote
If everything else fails you can alway take a screenshot and print that one, from within another program...
Lutz
TomTom/TeleAtlas NAVTEQ
Oldie
PostPosted: Fri Apr 30, 2004 6:44 am    Post subject: Reply with quote
Pazza,
This bug has been corrected in MMN 4.2.2 which is available for download. Use the MMN menu item Web and Check for Updates... to locate the new version.
Pazza
PostPosted: Sat May 01, 2004 11:15 am    Post subject: Printing in MemeoryMap Reply with quote
Thanks for the suggestions - all has failed and I have been printing in another program which allows better editing but MM is quicker. The update has not had any effect so I'm still puzzled. Is it only me? It happens every time now so it looks like something 'permanent'. I am on Windows ME could that be the problem?
