Pocket GPS World :: View topic - NAV-U 92T
NAV-U 92T
smogf
PostPosted: Thu Dec 27, 2007 2:30 pm    Post subject: NAV-U 92T Reply with quote
I've just deleted nav-u.exe file from my NAV-U 92T
Could any one have that model and could send me this file to: smogfikATgmail.com ?
Thanks,
email address edited by MaFt to avoid spam! (replace AT with @)
martinx
PostPosted: Sun Dec 30, 2007 12:31 pm    Post subject: Reply with quote
If you still need it, I can send you file in the evening.
ukn
PostPosted: Thu Jan 03, 2008 8:57 pm    Post subject: Reply with quote
Oh please send me this file too !
ukn [at] noos.fr
email edited to reduce spam - PaulB2005
swierk
PostPosted: Mon Feb 04, 2008 12:08 am    Post subject: deleted nav-u.exe please help Reply with quote
I`ve deleted that file too, insted of renaming when I was unlocking windows. I didn`t know that its not supplied to product DVD. Crying or Very sad
Could someone help me, sending that file to swierqu83ATwp.pl
THX
RichDem
PostPosted: Tue Feb 05, 2008 6:55 am    Post subject: Reply with quote
I would be interested in knowing how you unlocked your device to access windows. I have a U-93T and would like to experiment with other software.
Many thanks
If it ain't broke then fiddle with it until it is!
swierk
PostPosted: Tue Feb 05, 2008 3:29 pm    Post subject: Reply with quote
It`s very easy. You just have to rename the file named nav-u.exe to nav-uold.exe (browse the device by active sync). It`s stored in \Mounted Volume\Sony\nav-u on the device. Then you had to copy showtaskbar.exe (I can send you that file) to the same directory oryginal nav-u.exe was stored and renamed nav-u.exe.
Unplug the device from computer and you have unlocked your navu.
It work on u92, sould work in yours
The minimalized taskbar is on the bottom(press to slide up, you could turn off autohideing in control panel)
If you can`t rename the oryginal file. You just reboot the device before you pluged in to computer
Could you send me contens of your \Mounted Volume\Sony\nav-u directory archiwized by rar or zip. swierqu83ATwp.pl
thanks, regards from Poland
ps.sorry 4 poor english
Bughy
PostPosted: Fri Mar 28, 2008 7:18 am    Post subject: Reply with quote
Hy.
Can u sent me also that file, pls?
BTW, Greeting from Romania
niall_UK
PostPosted: Sun Mar 30, 2008 7:08 pm    Post subject: Reply with quote
hmmm I have a nv-u53g and showtaskbar.exe doesn't work... my unit goes through a reset cycle and the calls for a service...
Coolhawk
PostPosted: Fri Apr 18, 2008 8:26 am    Post subject: Reply with quote
Anyone had any success in running ANY other navigation programs on the U92T? I get to the Windows CE interface and have been trying to run the following navigation programs, Igo 2006, Igo 2008, Destinator 7, TomTom, Navigon 6.5 and MioMap, but none of them can see the GPS, and trust me I've tried all tricks and turns on sys.txt for Igo and MioMap, Destinator manual tried all ports, autosearch, but it does not find it at all. In registry the GPS serial is listed as on COM 5, in the original files on device it's listed in SPGPS.ini as on COM 3. BUt none of them is working.
After some more digging into it, the U92T has also a pressure/acceleration sensor build for the famous "GPS Plus" which keeps navigating in tunnels ect, but for this I only find one reference in registry which is listed as PosSensor/PSD1, but no reference to COM port.
Also I've tried out Franson GPS gate, also tried POI Observer Virtcom Batcher combination, but everytime the GPS is not detected, found or give any data, only with the original program it's working correctly.
Would really appriciate is anyone have any idea how to setup or change settings in order to get to this GPS com port.
Been playing for over 3 years unlocking PNAs/PNDs, but it's the first time I'm stuck with a device like this.
Regards
ChrisKav
PostPosted: Mon Jul 07, 2008 3:49 pm    Post subject: Reply with quote
I have heard to turn on the gps with the sony is hardcoded in the original nav-u.exe, so there lies your answer. I even tried gps gate, but eventually gave up and got rid of it. I hated the version of Navigon it used. Igo/Dest/miomap system will only operate in system that have the gps already activated.
The viewing screen of the Sony was so cluttered and slow. Unbelievable poor performance. I thought I was up grading from my Mio C710 3.5" LCD and wanted a widescreen with TMC, but I was very dissappointed.
I settled for a Harmon Kardon GPS (great built in TMC receiver). These devise are easy to unlock, have a version of igo2006 already built in and the GPS is activated all the time. So it will work with any system.Widescreen 480 x 272 is also available in a very sturdy compact case.
Just thought I would put my point across as it could prove usefull in a GPS decision making process.
22.123 (18 Dec 24)
