Pocket GPS World :: View topic - Truvelo/Gatso
Truvelo/Gatso
kshotton45
PostPosted: Mon Jan 28, 2008 10:35 am    Post subject: Truvelo/Gatso Reply with quote
Hi, I am just wondering if it would be a good idea to have separate lists for Gatso and Truvelo. I would have thought that a Truvelo needs more warning as it faces you.
Cheers Keith.
PostPosted: Mon Jan 28, 2008 11:04 am    Post subject: Reply with quote
I think this has been mentioned before, and I think the answer is contained in the quote:
What camera database categories do I need?
Single File:
Consolidated by Type:
Speed Zoned:
(with descriptions of the pros and cons of each)
There are almost an endless amount of combinations of the above.
In other words, yes that is an idea, but if they produced every different version that you could think of (red light split into speeds? temp section split up and merged into the "fixed" sections? etc.) they'd never get the database out on time, if at all!
But, there is nothing to stop you creating the seperate files yourself with a utility like POI edit. Simply load each "Gatso" file (20,30,40,50,60,70,tba if you are using the speed zoned set) into POIEdit one at a time, then click the name column to sort the list alphabetically and you can then split the list into as many sections as you like using normal copy and paste or delete, then "save as" with new names. (You'll obviously need a new set of icons for the new files too).
PostPosted: Mon Jan 28, 2008 11:12 am    Post subject: Reply with quote
It's also worth considering that a Truvelo takes your photo at a range of about 10m so in practice it makes little difference if they have their own database. You really should be setting warning of 300m+
Also Truvelo can operate in dual mode with front facing for approaching traffic and the ability to take rear facing shots of traffic on the opposite carriageway.
kshotton45
PostPosted: Mon Jan 28, 2008 11:57 am    Post subject: Reply with quote
Thanks for your replies. I thought this may be the case. I've already separated Truvelo from Gatsos ( just for the excercise, as I'm having a new Garmin and I want to find my way around it ! )
Regarding the Truvelo taking a photo at 30 m. Has it, by then, detected that you're over the speed limit?
Keith.
kshotton45
PostPosted: Mon Jan 28, 2008 11:58 am    Post subject: Reply with quote
Ooops! I meant 10 m !!!
PostPosted: Mon Jan 28, 2008 12:01 pm    Post subject: Reply with quote
It must have done... otherwise why would it take a picture at all? Very Happy
gary10
PostPosted: Mon Jan 28, 2008 1:14 pm    Post subject: Reply with quote
So if it takes a picture at 10m and knows youre over the limit how far away can it detect you ?
Time for bed says Zebadee
TomTom 720
PostPosted: Mon Jan 28, 2008 1:33 pm    Post subject: Reply with quote
At about 10m! Truvelo uses piezo strips in the carriageway which trigger the camera.
Following the sensor strips is a band of three white lines painted across the carriageway. The Truvelo photo will actually show your vehicles front wheels centered on the white lines having measured your speed a split second before. This is used as a secondary check to confirm which vehicle is the guilty one should there be more than one in the photo.
In the photo above you can see then measurement strips followed by the white lines. (Photo Courtesy of TruveloUK)
kshotton45
PostPosted: Mon Jan 28, 2008 1:49 pm    Post subject: Reply with quote
This is the point I was making. Realisticly, you need more warning when approaching a Truvelo.
I've separated my Gatso/Truvelo file and intend to give the Truvelo 100 yards more that a Gatso.
Am I going 'over the top' ! or does that sound reasonable ?
Cheers Keith.
PostPosted: Mon Jan 28, 2008 1:57 pm    Post subject: Reply with quote
It measures your speed and takes your picture at 10m. If your warning are so late that 10m makes a difference then you need to change them ALL!
PostPosted: Mon Jan 28, 2008 2:29 pm    Post subject: Reply with quote
10 yards for every ten miles per hour gives aprox. 20 seconds warning. That's ample for Truvelo or Gatso.
Don't forget, if you split all the files in two this time, you'll have to do it again in a fortnight and every time there's a new release of the database.
PostPosted: Mon Jan 28, 2008 4:55 pm    Post subject: Reply with quote
Andy. Surely your rule of thumb should be 10yd for every 1 MPH
so for 60MPH
60MPH = 88ft/sec X 20 = 1760ft = 1/3 mile = approx 600 yds
otherwise the warning is at 60 yards for 60MPH, a bit close? Wink
PostPosted: Mon Jan 28, 2008 6:06 pm    Post subject: Reply with quote
Yes, you're right of course Embarassed
What I meant to say was set the distance to ten TIMES your speed... in yards.
kshotton45
PostPosted: Mon Jan 28, 2008 6:16 pm    Post subject: Reply with quote
Super !
You've been helpful, it's appreciated.
Keith.
Ash10
PostPosted: Mon Jan 28, 2008 7:59 pm    Post subject: Re: Truvelo/Gatso Reply with quote
Truvelo cameras also have Type Approval for rear-facing application...
22.064 (26 Jun 24)
