Pocket GPS World :: View topic - Help please, TT 700 won't turn on.
Goto page Previous  1, 2
PostPosted: Wed Jan 23, 2008 3:49 pm    Post subject: Reply with quote
Sorry, I don't know the TT ONE. I presume that going back to the shop in Ireland is not an option? So I can only offer useless suggestions, like shout at the thing.
Seriously, I can't understand that the reset wouldn't push in - did you use a small enough poking thing? They usually click dead easy if you get the poking thing into the hole.
Normally with TT devices, the fierce cure is to hold the reset button depressed for several (15?) seconds. To switch on again, hold the power button pressed until it actually starts to fire up. You can try the reset both when it's got power of some sort (green light?) and when it's switched off.
PostPosted: Wed Jan 23, 2008 4:12 pm    Post subject: Reply with quote
What type of TomTom One is it? - does it have a memory card in it or not, if so remove the card and then re-insert it, this will reset the device, although the reset button should be working (have you tried usng a pin) as some of the TT units have a small switch which only a pin will opperate correctly - Mike
Toneloc427
PostPosted: Wed Jan 23, 2008 4:43 pm    Post subject: Reply with quote
Try eating a steak and then turning them on. I think it's the lack of iron in your blood from just eating veggies! Very Happy
PostPosted: Thu Jan 24, 2008 1:20 am    Post subject: Reply with quote
Confirmed veggie here, and I can USUALLY summon up enough strength to unbend a paper clip to poke the reset hole with. Smile
Vegnomeat.. If two devices just die in this way without help, you must be really unlucky. Are you sure you've not done anything "unusual"? Unplugging from the PC without either using "safely remove hardware" in the system tray or "disconnect device" in Home, are a good way to trash a TomTom.
PostPosted: Thu Jan 24, 2008 8:34 am    Post subject: Reply with quote
Other people get unlucky too! (or is that unlucky five?) Sad
PostPosted: Thu Jan 24, 2008 10:38 am    Post subject: Reply with quote
You're a special case Dennis.... Wink
vegnomeat
PostPosted: Thu Jan 24, 2008 10:54 am    Post subject: Reply with quote
Thanks for the replies gents.
The TT One doesn't have an external SD memory card. Also I haven't unplugged it from a PC as I never managed to get it switched on Smile
TT have agreed to replace the original GO (or don't go) 700 and I have an RMA number.
As for the TT One, the supplier has agreed a full refund when I return the item.
Oh, and I bought a Collins map, worked a treat and never ever failed to open on the right page. Also the pages look like they will last a long time without needing re-printing Smile
Vegnomeat
PostPosted: Thu Jan 24, 2008 8:32 pm    Post subject: Reply with quote
My road atlases used to last about six months before they started coming apart. The last two I stitched up to prevent the coil bindings from coming out - it took me considerably longer than setting up the latest pgpsw cameras on my three devices this morning. The road atlas I have on my overhead shelf now, is two years old and almost mint condition since I so rarely pick it up. And the box full of street maps now lives in the shed because they too haven't been use in two years.
Mind you, I'm on my GO720s #6 and #7 (but only on GO920 #1). Very Happy
For what it's worth, I think the GO700 was close to being the best TomTom device.
PostPosted: Thu Jan 24, 2008 9:17 pm    Post subject: Reply with quote
I still think the Classic is one of the best.
It did one thing and did it well. For getting from A to B it's as good as the top of the range models. The only drawback is the Chipset, but that's progress.
If TT went back to doing a basic Navigator, without the frills and with no crippled menus, I think they would be on to a winner.
vegnomeat
PostPosted: Fri Jan 25, 2008 12:05 pm    Post subject: Reply with quote
What I can't understand is why TT's are so unreliable and suffer so many problems.
When I spoke to TT support they weren't in the least bit surprised that the unit wouldn't switch on.
I own a software business and we write software for the electronics industry and support over 3500 customers worldwide.
If my software worked to the standard of TT's I would be catching the bus to sign on instead of driving around in a flashy motor Smile
Regards
vegnomeat
dhn
PostPosted: Fri Jan 25, 2008 2:43 pm    Post subject: Reply with quote
vegnomeat wrote:
Nothing worked at all.
As I was working away in Ireland and really needed a satnav I purchased the TT One.
Guess what, it wouldn't turn on and the reset button wouldn't push in. Eventually I managed to get some life but am now stuck on a green screen that says "Success!!" Except that it is stuck on and won't turn on, or attache to a PC
Must be me
As silly as it sounds .... and I am NOT being patronizing .... a user on a North American forum was having a similar problem about his unit and trying the 'reset' with continued frustration .... until he realized he was sticking the pin into the antenna receiver hole and not the true reset hole on the unit.
Just a thought.............
PostPosted: Fri Jan 25, 2008 2:52 pm    Post subject: Reply with quote
Just in case dhn is correct check the location of the reset switch on This Page, I know of quite a few x10 devices where the microphone was ruined because people were sticking pins in it thinking it was a reset hole! - Mike
PostPosted: Fri Jan 25, 2008 6:09 pm    Post subject: Reply with quote
Also om the x10 Devices the Pinhole is much smaller than any of the other Devices.
PostPosted: Sat Jan 26, 2008 7:25 pm    Post subject: Reply with quote
Joker "senior moment" Oldboy??
You told ME off about mentioning the x10 back on page 1! Laughing
PostPosted: Sat Jan 26, 2008 10:41 pm    Post subject: Reply with quote
Been one of those weeks. Laughing
Just read Mike's Post -
.... I know of quite a few x10 devices ...
Embarassed
Page 2 of 2
22.064 (26 Jun 24)
