Pocket GPS World :: View topic - Can't upload database- help
Maymo
PostPosted: Mon Jan 21, 2008 3:57 pm    Post subject: Can't upload database- help Reply with quote
Am I missing something?
I am trying to install the Speed Camera Database on my Garmin Nuvi 370 using POILoader. I tried to use Ash’s Camera Manager v2.5, this seems to work as described in the forum, the POI’s seem to load onto the device, but I can’t see them.
When I test the Nuvi by driving past a speed camera it is not on my map, no warning, no icon, nothing. I have scrolled around the map looking for other cameras that I know of and there is no icon there either. I can see icons for other POI’s that I have loaded eg Aldi, Tesco etc. but not the cameras.
I then downloaded the database manually and installed it using POILoader, the same thing happened, I can’t see the cameras. Which would be the most appropriate version to use, I have tried the POILoader / Speed Zoned Complete.
I have the Garmin Safety Cameras unticked and the Custom POIS ticked and I have Audio Notification single tone ticked.
Help!
Maymo
Sad
PaulB2005
PostPosted: Mon Jan 21, 2008 5:59 pm    Post subject: Reply with quote
Is there an option to turn Proximity Alerts on and off?
Also what distances did you use with Ash10 software?
Maymo
PostPosted: Mon Jan 21, 2008 7:17 pm    Post subject: Reply with quote
I have gone to Settings, Proximity Points, Alerts, change, and enabled Custom Pois and disabled Garmin Safety Cameras
I used the default distances with Ash10, in fact I used all the default settings
Maymo
PaulB2005
PostPosted: Mon Jan 21, 2008 7:26 pm    Post subject: Reply with quote
When you use POILoader is it set to manual or express?
Really feel like i'm missing something obvious here.... Confused
Maymo
PostPosted: Mon Jan 21, 2008 9:36 pm    Post subject: Reply with quote
It's set to express.
I have just sussed out what's wrong. I had left my SD card in the unit every time I uploaded the pois. In POILoader I selected the Garmin unit and not the SDcard but the data seems to have ended up on the card. On startup I got a message asking if I would like the new dada on the card installed to the unit, I clicked yes. This did not work.
I have just tried POILoader again without the card in and the cameras have been installed to the GPS, I can now see the icons for the cameras. Problem solved. I don't know if this has been highlighted before but perhaps a note in the instructions that you must remove the card before loading pois on the Nuvi 370.
Thanks for your help in trying to solve this one Smile
Regards
Maymo
22.064 (26 Jun 24)
