Tuts Occasional Visitor
Posted: Fri Apr 23, 2004 9:12 am Post subject: New install - help needed |
I've just done a first time install of TT3 to my ipaq 3630 but when I try to run it I get the message "You need to load a map from the TT Navigator CD". I have loaded a map but to my storage card via the install program because I don't have mauch space left on my ipaq. So why is it complaining ? All I can do is press OK and return to the Today screen.
I have sent a mail to TT support but I thought I might get it sorted faster through this forum.
Cheers |
Steveg Regular Visitor
![](modules/Forums/images/avatars/d413576c408938211a02a.gif)
Joined: Mar 29, 2004 Posts: 198 Location: Leeds, West Yorkshire
Posted: Fri Apr 23, 2004 10:46 am Post subject: |
Hmmm,Don't actually know the answer to this, but if I were in your position I would be very tempted to uninstall the whole thing (including SD card) and re-install afresh, in case these was some minor glitch when installing the first time. If it does the same after a new clean install then there must be some other problem to be investigated.
Sorry I cannot help more
Steve |
MrT Frequent Visitor
![](modules/Forums/images/avatars/gallery/065.gif)
Posted: Fri Apr 23, 2004 11:46 am Post subject: |
I got this fault when I started TomTom wizard rather than TomTom itself. I would check as I think the icon in your menu calls the wizard until the program has run for the first time. If your icon has a yellow star in one corner, that is the wizard program.
I am not sure if I fixed this by running the main program from file manager or by applying the 3.01 update. |
samriley Occasional Visitor
Posted: Fri Apr 23, 2004 12:13 pm Post subject: |
this can be fixed by uninstalling the tomtom wizard, then using the explorer navigate to /Program Files/Navigator <- you then need to rename the Tomtom Navigator.exeo to Tomtom Navigator.exe |
Posted: Fri Apr 23, 2004 2:36 pm Post subject: |
Thanks for the replies, Sam how do I view the files extensions in PPC2002. |
Darren Frequent Visitor
Posted: Fri Apr 23, 2004 2:46 pm Post subject: |
It's far easier to use explorer on your PC with your PPC docked. You can then see the file extensions. _________________ Darren Griffin |
Posted: Fri Apr 23, 2004 3:15 pm Post subject: |
Thanks guys you're absolute stars, you beat TT support anyway. I did what Sam suggested renaming via my PC and it works fine.
Thanks |
