Pocket GPS World :: View topic - Warning - broken speed camera alerts with new Nuvi firmware
swing
PostPosted: Fri Jan 18, 2008 9:25 am    Post subject: Warning - broken speed camera alerts with new Nuvi firmware Reply with quote
Garmin have recently released an update to their Nuvi 310 and 360 range, the v4.40 software. Now, this has a couple of useful fixes in it from the previous firmware, so many people may be inclined to upgrade. However, I think I have found an issue with this firmware, which I want to advise people of before they upgrade. I use mp3 speed camera warnings (which may play a part in this problem)
Firstly, this upgrade seems to bring with it a bug seen in the latest 660 firmware - whenever a speed alert is played, if you have an mp3 file playing, it jumps to the next song, instead of pausing, and returning to where you were. This, in itself, is a nuisance, but not the end of the world.
However, after driving along wondering why my unit was constantly moving to the next song, I figured it out....
If you are playing mp3 music, and you are approaching a speed camera (using the PGPSW database), instead of changing the screen to have a red banner and playing the warning, it FAILS to play the warning; although it updates the screen and displays the correct text, no mp3 warning file is played - it simply skips to the start of the next song.
Having turned off the music, the unit, without a reboot, started playing the mp3 warning sounds fine.
So, this means (in my opinion), I have a choice - I either have no music via the unit, or I will downgrade to v4.30, and I advise others to consider the same choices.
Of course, for those who don't play music via their Nuvi, everything will be well.
Please don't be offended if I do not reply to a PM - please ask questions via the forums.
PhilHornby
PostPosted: Fri Jan 18, 2008 1:13 pm    Post subject: Re: Warning - broken speed camera alerts with new Nuvi firmw Reply with quote
Maybe V3.90 is a better bet - V4.30 had the "Detour" button bug - whereby you couldn't get back to the menu after you'd pressed it.
madhatter
PostPosted: Fri Jan 18, 2008 7:13 pm    Post subject: Reply with quote
had the same issue with the latest 660fm firmware. solution= convert mp3 voice speed warning files to wav and load using older version of poi loader. Solved problem of tracks skipping whilst listening to mp3's etc. Garmin are aware of this and told me to do this.
swing
PostPosted: Sat Jan 19, 2008 3:20 pm    Post subject: Reply with quote
Ah - that's nice to know, although I only moved away from WAV files to MP3 files a month or two back - gah! Thankfully as well as saving the installer, I also saved a copy of the WAV files Smile
22.064 (26 Jun 24)
