Pocket GPS World :: View topic - Navman icn 530
Navman icn 530
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navman Handhelds
jimbo1951
PostPosted: Wed Jan 16, 2008 10:37 am    Post subject: Navman icn 530 Reply with quote
I got given a Navman icn 530 for xmas it worked fine the first 2 times i used it when i turned it on the other day and went to "go to" it said "No map data available" we got it cheap from dixons belive it was because the setup disks and manual was missing can anyone help how i can get the maps to work again please. or have been given a door stop as a prezzie.
Thanks in advance
Jim
mostdom
PostPosted: Wed Jan 16, 2008 11:51 am    Post subject: Reply with quote
Hi Jimbo1951, Welcome to the forum.
Couple of questions.
Do you have any sort of memory card inserted into the side slot, if yes try removing it?
Do you at least have the Smart ST software CD?
Within the menu options (and I forget where) there used to be a screen to show what maps are installed if any. Does i say any maps are installed?
Do you remember doing anything significant between now and the last time you used it?
Dom
jimbo1951
PostPosted: Wed Jan 16, 2008 8:38 pm    Post subject: Reply with quote
There is'nt a memory card in the side slot, and I did'nt get the smart st disks with hence why i got it cheap fron currys. the only thing i did between using it the last time and this time was turn it off and back on.
But I have found that my son downloaded smart st off the internet and ran it on the computer. he has now emigrated to a far off dark corner of the planet Laughing Out Loud.
Thanks for your reply
Jim
mostdom
PostPosted: Wed Jan 16, 2008 11:51 pm    Post subject: Reply with quote
If you want to refer to the Manual use this link Here.
A quick read suggests you need Microsoft ActiveSync 3.7.1 - and Navmans Smart ST which your son may have installed already, connect the icn530 with an appropriate usb cable if you have it and you should be able to see what maps are installed and if there is any problems.
There is no obvious reason as to why your device would just stop using the maps or suggesting that they are not installed when they were there only a day before.
A call to navman support would be a good thing to do at this point, as they may have experienced this before and know how to fix it. You may also have to consider buying a new map set but that is a last resort at this point.
Dom
robertn
PostPosted: Thu Jan 17, 2008 9:19 pm    Post subject: Reply with quote
A mixup in bersions will cause this problem. New version software can't use older maps and vs versa. If he has done an Updgrade, you will need disks to install the original version - give Navman a call.
If it ain't broken, don't fixit
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navman Handhelds All times are GMT + 1 Hour
