Pocket GPS World :: View topic - GPS speed accuracy Vs speedometer?
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Post new topic   This topic is locked: you cannot edit posts or make replies.    Pocket GPS World Forum Index -> TomTom Portable Navigation Devices
nivek22
PostPosted: Tue Jan 15, 2008 9:34 am    Post subject: Reply with quote
tgold wrote:
I am surprised that a vehicle technician believes inflation pressure affects the rolling circumference of a tyre or the accuracy of the speedometer. Anyway, I look forward to reading your results.
Tony
If you take this to extremes and consider a flat tyre. The diameter has reduced by about 6 inches, so the circumference will have reduced proportionately. (Can't be bothered to work it out).
Snudge
PostPosted: Tue Jan 15, 2008 10:51 am    Post subject: Reply with quote
1)Take a piece of string 1 metre long and make it into a circle to represent an inflated tyre and measure the circumference. (It's got to be 1 metre.)
2)Now make it into the shape of a flat tyre and measure the circumference.
Is there a difference?
( I think the thread has gone the same way as the last one on this subject - sorry for contributing Smile )
StanStill
PostPosted: Tue Jan 15, 2008 11:15 am    Post subject: Reply with quote
What nobody has mentioned is that tyre wear plays a part in the accuracy of your speedo reading. A new tyre has a greater circumference than a worn down one. I think this is one of the reasons that manufactures have to build in a bit of slack in their speedo readings.
if1977
PostPosted: Tue Jan 15, 2008 1:46 pm    Post subject: Reply with quote
OK, Here goes.
I took a brand new car out for a test drive about an hour ago and it was a mid-range 5-door with 195-55-15 tyres on it (alloy wheel 5 stud). I did as i said in the previous post and the findings were. Just for re-assurance another college was driving so i could consentrate in the screens.
At 30mph (According to the cars speedo) the actual speed of the car(according to the diagnostic machine in parameters) was 28mph and the speed according to the satnav was 33-34 mph(changed between these about 4 times in a 20 second stretch). We done the same test at 70mph (according to the cars speedo) the actual speed (according to the diagnostic machine) was 66mph and the speed according to the satnav was 75 mph. These were carried out when it was raining and on straight(ish) roads and at a constant speed for 20-30 seconds.
A bit of technical jargon.
On the same make of car wether it has 13'', 14'', 15'', 16'' wheels and does not matter what size of tyre it is the speedo drive( which is in the gearbox and measures the speed of the cars drive shafts) then sends the information to the cars ECU ( Electronic Control Unit) which then adjusts the speedo reading to legal % adjustment for the road and then that reading is the one that gets sent to the speedo head in the car which you see. So this is why if you change the wheel or tyre size of the car it will change the revolutions of the driveshart which will give the ECU a different reading and that will give the speedo head a wrong reading also.
Tony
It depends on how flat or hard the tyre is because if the tyre is over inflated and it is a slippy road then this will cause the tyre to spin more than the correct pressure and give you a faster reading than you are actually traveling or if it is about 5-10 psi (Flat) this will cause the tyre to broaden and that will put the car closer to the road and will cause drag which also could alter slightly(probably wont notice) and will also put ther car under load and burn more fuel.
I would also like to say that my Astra and TT do not agree by a long shot. When the TT says i am doing 70mph my car speedo says i am doing about 78mph and my Astra is the way it came from the factory. How do they explain this.
As i say these are the readings i saw with my own eyes and the technical jargon came out of a franchise manual for that spesific car so i cannot disagree with it. And if you find your readings between your speedo and satnav are large then maybe the wheels on that car were not standard from the factory.
If you have any questions i will answer them as best as i can and if you would like to know more about it just ask.
NEW Tomtom GO 500 (hope it is good)
iphone (running all day, doesn't like it)
XL LIVE IQ Routes (Got stolen and miss it)
GO 510 (in drawer now, time for upgrade)
jspencer
PostPosted: Tue Jan 15, 2008 3:28 pm    Post subject: Reply with quote
How does the diagnostic machine arrive at its readings?
Jon
Robin2
PostPosted: Tue Jan 15, 2008 4:28 pm    Post subject: Reply with quote
If the TT speed is 70 mph (+/- 1 mph) and the Astra's speedo says 77 mph it is (just) within tolerance, which is +7/-0 mph at 70)
The higher speeds shown by satnav in if1977's comparative test are completely at variance with my own experience in many cars, and also results quoted in this forum by a large number of other contributors.
Given that the results obtained by the diagnostic machine are about what I would expect, I can only conclude that the satnav used in the test was defective
Robin
Satmap Active 10
if1977
PostPosted: Tue Jan 15, 2008 5:12 pm    Post subject: Reply with quote
I did not do the test in my Astra Robin2. I just added that at the end to tell people what my car was like. My Astra is a 1998 model and has about 80k on it so it is not the newest car and will have some wear and tear to it and would say my satnav is OK because it has been checked with others.
PostPosted: Tue Jan 15, 2008 5:54 pm    Post subject: Reply with quote
Ian, from what you describe the car you took for a test drive is illegal, I would not expect the GPS speed to be inaccurate enough to explain the difference you observed, had the car been modified in way by the garage - Mike
if1977
PostPosted: Tue Jan 15, 2008 6:39 pm    Post subject: Reply with quote
It was a new car that had been delivered in a batch of about 10 and was checked for the road and had a CD multiplayer fitted and mudflaps and floor mats, otherwise it is the way it came off the lorry with a delivery milage of 000007 miles on the clock.
Why do you think this innacuracy would make the car illegal or altered in any way.
PostPosted: Tue Jan 15, 2008 6:51 pm    Post subject: Reply with quote
mikealder wrote:
I wonder if this thread will go the same wandering path the last one did that related to speedo accuracy?
Looks like...... Laughing
PostPosted: Tue Jan 15, 2008 6:55 pm    Post subject: Reply with quote
Obviously not, but that's nothing to do with the situation here.
what IS relevant is the effective radius of the inflated or deflated tyres.
When running on a deflated tyre the distance between the centre of the wheel and the road is smaller.
Imagine the extreme example of no tyre - running on the rims, and that certainly means a smaller circumference, doesn't it.
tgold
PostPosted: Tue Jan 15, 2008 7:00 pm    Post subject: Reply with quote
As I understand it the legal tolerance is +0 and - (10% plus 10kph). So if a new vehicle travels at 70 mph and its speedometer reads anything between around 56.75 mph and 70 mph it would meet the legal requirements under the Construction and Use Regulation, now based on Community Directive 97/39.
Tony
tgold
PostPosted: Tue Jan 15, 2008 7:05 pm    Post subject: Reply with quote
Maybe forget "radius" for a non-circular tyre and consider just the perimeter, called the rolling circumference. And when considering it, imagine it is made from steel belting which is virtually inelastic. Does that change the picture? Obviously if you remove the tyre and run on the rims, that is not an extreme example of deflation but quite a different situation altogether.
Tony
PostPosted: Tue Jan 15, 2008 7:07 pm    Post subject: Reply with quote
With a GPS speed of 70 mph I would expect the vehicles speedo to read between 70 to 77. What is not acceptable is for the vehicles speedo to read under the actual speed the vehicle is travelling at, so where you had a speedo reading of 70MPH and the GPS speed was indicating 75 the speedo is illegal - it is enticing you to break the law - Mike
PostPosted: Tue Jan 15, 2008 7:17 pm    Post subject: Reply with quote
Tony
Nope, I still disagree. When the tyre is totally deflated, isn't that virtually the same as running on the rims? The car is certainly nearer the ground, that's why they deflate the tyres on trucks to help get them under low bridges.
So (I think) the effective circumference is defined by the new (smaller) radius.
It's a good puzzle though... I'm going to ask our resident work genius about it tomorrow. Smile
Post new topic   This topic is locked: you cannot edit posts or make replies.    Pocket GPS World Forum Index -> TomTom Portable Navigation Devices All times are GMT + 1 Hour
Page 2 of 8
