Pocket GPS World :: View topic - unsuitable routes for caravans
HOOPEY
PostPosted: Fri Aug 17, 2007 8:46 am    Post subject: unsuitable routes for caravans Reply with quote
My father owns a TomTom 710 which he uses mainly when caravaning both in the Uk and europe. This year when in France the sat nav took him along roads which were not really suitable for caravans. My Garmin 510 has an option to change it to deal with different types of vehicle for example trucks. Is there a similar feature on the Tom Tom and if so where can he find it. If there isn't can anybody suggest a way of getting round his problem.
Thanks in advance.
alix776
PostPosted: Fri Aug 17, 2007 9:04 am    Post subject: Reply with quote
the options in the garmin maynot help avoid unsuitable roads what setting did he have the tomotm set to
device Lumia 950 xl
HOOPEY
PostPosted: Fri Aug 17, 2007 9:15 am    Post subject: Reply with quote
what options are there on the TomTom ?
Flack
PostPosted: Fri Aug 17, 2007 9:53 am    Post subject: Reply with quote
I have had the same problem as I use my TT910 when I tow my caravan, but what I have found best to use is, plan a route using Google earth then view the route first to see if its suitable for a caravan.
Then if it is I then plan the same route in Auto Route then use ITconvert so I can transfer the route to my TT and use it.
The plus side using Auto Route is you can tell the software what roads you dislike & like.
With a lot of sites now having wifi connections its very easy to do from inside your van and plan the next route
Also I choose the limited Speed option on my routes as I take it this is for HGV's, it has worked for me so far.
Flack Very Happy
arfurdent
PostPosted: Fri Aug 17, 2007 1:05 pm    Post subject: Reply with quote
I think you'll find that any road is unsuitable for a caravan particularly if I am behind it
Fibre
PostPosted: Mon Jan 14, 2008 12:39 pm    Post subject: Reply with quote
Flack Very Happy
found this post interesting as a Caravaner and a TomTom Go (clasic) person.. would dearly love to find the answer..
I do have Autoroute2005 (Not GPS though) on the laptop -- and would be interested to see how to transfer routes from AR to TT??
Also the "Limited speed" option -- how does that work for caravan routing??
Hope you dont mind me asking..
Maurice
Happy to meet -- Sorry to part -- Happy to meet again
PostPosted: Mon Jan 14, 2008 1:16 pm    Post subject: Reply with quote
There are several improvements in the latest AutoRoute, 2007. More roads for one thing.
But in either version, you create the route you want using PushPins. In AR, use the Route Planner to pull the desired Route into shape.
Save the File in standard AR .axe format.
Then, using a program called ITNConv, the PushPin data is converted into an Itinerary File that you can copy to the itn Folder on the Device.
Fibre
PostPosted: Mon Jan 14, 2008 1:25 pm    Post subject: Reply with quote
thank you will have a "play " this afternoon
Smile
Maurice
Hoppy
PostPosted: Mon Jan 14, 2008 4:45 pm    Post subject: Reply with quote
I believe a new feature of Google maps is to work out a route then transfer to your TomTom, could be worth a try.
TomTom Go 950 Live.
App 9.054
Europe v8.50
NA 2GB v8.45
LT
PostPosted: Wed Jan 16, 2008 12:27 pm    Post subject: Reply with quote
Potentially you could set the speed limit option? A friend of mine who's a coach driver does this and I think it then avoids narrow roads etc. I could be wrong, but I think that's the case...
22.063 (19 Jun 24)
