Pocket GPS World :: View topic - update 7.0.3 on X-970T then TMC does not work anymore
stollvor
PostPosted: Sun Jan 13, 2008 9:55 pm    Post subject: update 7.0.3 on X-970T then TMC does not work anymore Reply with quote
I have just installed the new available release software 7.0.3 and now the TMC does not work anymore. It is impossible to connect to a Traffic Info Service. Still Searching...
The Traffic Info Options is ON.
Does somebody encounters the same problem ?
After installing the new release, do I have to perform a specific configuration to get the TMC working ?
Thanks for your help.
Stollvor
jlo
PostPosted: Sun Jan 13, 2008 10:52 pm    Post subject: Reply with quote
Sorry to not be much help buy I upgraded my X970T to 7.03 and no probs at all with TMC. I am sure some more experince users will be on hand to help answer your question.
Good luck
Jlo
jonandmarkuk
PostPosted: Mon Jan 14, 2008 12:29 pm    Post subject: Reply with quote
I had this problem one evening, switched the unit off and tried again the next day and it worked fine. It could be an issue with the TMC transmission in your area?
Have no way of knowing if TMC is up and running as like a lot of things it could suffer outages?
stollvor
PostPosted: Mon Jan 14, 2008 7:19 pm    Post subject: Reply with quote
Switching off the unit was not enough, I had to reset it (I pressed the reset button on the back side of the unit)
Thanks jonandmarkuk, you put me on the right way to solve my problem.
Stollvor
