Pocket GPS World :: View topic - SD Card of 2 GB and MAp V7
cyberbot
PostPosted: Sun Jan 13, 2008 11:06 am    Post subject: SD Card of 2 GB and MAp V7 Reply with quote
i have Got SD card of 2GB
Can i install the map 7 Wich are 1.89GB ? in this SD ?
Thanks guys
PostPosted: Sun Jan 13, 2008 11:19 am    Post subject: Reply with quote
Did you purchase the map? - Mike
cyberbot
PostPosted: Sun Jan 13, 2008 12:30 pm    Post subject: Reply with quote
yes i did and downloaded them
but when i save them in the SD
my tomtom Said Map not found
PostPosted: Sun Jan 13, 2008 1:50 pm    Post subject: Reply with quote
Did you use TomTom Home softare on the PC to install the map? this software package deals with map activation, if the device is reporting the "No Map" screen it usually means the map isn't activated - Mike
PostPosted: Sun Jan 13, 2008 1:52 pm    Post subject: Reply with quote
Just one other thought though, Have a read of This Thread which details using the clear flash tool set in order to activate a map, it sounds similar to your problem - Mike
cyberbot
PostPosted: Sun Jan 13, 2008 2:12 pm    Post subject: Reply with quote
I dont get anything that the map is not activated or something where to writ the activation code
Only Map has not been found that all
PostPosted: Sun Jan 13, 2008 2:19 pm    Post subject: Reply with quote
Map activation is handled automaticaly by TomTom Home you don't write anything down or put number in, have you tried the clear flash utility I linked to above? - Mike
cyberbot
PostPosted: Sun Jan 13, 2008 2:35 pm    Post subject: Reply with quote
hello mike
thanks for the help
i did tried the Flash but doesnt work
i have reisntalled and its still giving the same problem
dhn
PostPosted: Sun Jan 13, 2008 4:01 pm    Post subject: Reply with quote
cyberbot wrote:
hello mike
thanks for the help
To be clear, when you say 'reinstalled', you used TTHome to do the installing, you did designate the sd card to install it to and my understanding is that certain models of tomtom require the operating system to be installed on the sd card where the map is located (the 720 I have doesn't have this requirement).
Anyway, things to check.
cyberbot
PostPosted: Sun Jan 13, 2008 4:08 pm    Post subject: Reply with quote
thanks for the help
i did called and the problem is fixed
my ID device id was Faut
thanks again
PostPosted: Mon Jan 14, 2008 2:56 pm    Post subject: Reply with quote
I can't help wondering where this "SD card of v7 maps" came from....
Tim Buxton
PostPosted: Mon Jan 14, 2008 3:28 pm    Post subject: Reply with quote
Well the OP says he downloaded the maps, so I assume he has a 2Gb card kicking around on which to put them. Me, I have an 8Gb SDHC card. The maps came from TomTom and the card came from the USA, courtesy of Mike Barratt. Laughing
Tim
PostPosted: Mon Jan 14, 2008 4:08 pm    Post subject: Reply with quote
Humble apologies... I misread the original post. Thought it was an SD card purchased with maps on already.
22.063 (19 Jun 24)
