Pocket GPS World :: View topic - TT ONE V2 + Power On Problem
sollythegolly
PostPosted: Thu Jan 10, 2008 3:49 pm    Post subject: TT ONE V2 + Power On Problem Reply with quote
Just a query as to whether anyone else has encountered this problem, and if so, did they have a solution.
When TT1 V2 power on button pressed whilst unit is connected to external power source (pc or car lighter), unit will power on without problems. However, when power on button pressed whilst on internal battery, then nothing happens (no power, no nothing...).
If I power on whilst connected to external power source and then disconnect the power lead, then unit operates with no problems, and the battery indicator shows a fully charged battery. Unit will then power off as normal, but will not power back on unless reconnected to the external supply.
Today is the tomorrow that you worried about yesterday.
PostPosted: Thu Jan 10, 2008 4:25 pm    Post subject: Reply with quote
Tried a reset?
SEE HERE
sollythegolly
PostPosted: Fri Jan 11, 2008 10:40 pm    Post subject: Reply with quote
Yes, Andy. Initially this didn't work, but I powered it on whilst connected - removed the poer lead - ran the unit for about an hour on battery, then re-set. That worked.
One of life's little mysteries I guess.
Thanks for taking the trouble to respond. Have a good year.
Jim
PostPosted: Sat Jan 12, 2008 3:57 pm    Post subject: Reply with quote
Cool Thumbs Up
Thing to remember is the main on/off switch is NOT a power switch, it just tells the software to go into "sleep" mode, the program is still running. So if anything has got screwed it will continue like that until a proper re-boot.
HarryMonk
PostPosted: Sat Jan 12, 2008 4:07 pm    Post subject: Reply with quote
Had exactly the same problem (following updating this morning) and was just about to ask this very question when I saw this thread so a big thank you to Andy for the advice which has worked perfectly!
Chieron
PostPosted: Sat Jan 12, 2008 4:59 pm    Post subject: Reply with quote
I also had the same problem following an update yesterday, and a reset has now cured it for me as well ... Thank you folks.
23.021 (05 Feb 25)
