sollythegolly Lifetime Member
Posted: Thu Jan 10, 2008 3:49 pm Post subject: TT ONE V2 + Power On Problem |
Just a query as to whether anyone else has encountered this problem, and if so, did they have a solution.
When TT1 V2 power on button pressed whilst unit is connected to external power source (pc or car lighter), unit will power on without problems. However, when power on button pressed whilst on internal battery, then nothing happens (no power, no nothing...).
If I power on whilst connected to external power source and then disconnect the power lead, then unit operates with no problems, and the battery indicator shows a fully charged battery. Unit will then power off as normal, but will not power back on unless reconnected to the external supply. _________________ Today is the tomorrow that you worried about yesterday. |
Andy_P Pocket GPS Moderator
Posted: Thu Jan 10, 2008 4:25 pm Post subject: |
Tried a reset?
SEE HERE |
Posted: Fri Jan 11, 2008 10:40 pm Post subject: |
Yes, Andy. Initially this didn't work, but I powered it on whilst connected - removed the poer lead - ran the unit for about an hour on battery, then re-set. That worked.
One of life's little mysteries I guess.
Thanks for taking the trouble to respond. Have a good year.
Jim _________________ Today is the tomorrow that you worried about yesterday. |
Posted: Sat Jan 12, 2008 3:57 pm Post subject: |
Cool
Thing to remember is the main on/off switch is NOT a power switch, it just tells the software to go into "sleep" mode, the program is still running. So if anything has got screwed it will continue like that until a proper re-boot. |
HarryMonk Occasional Visitor
Posted: Sat Jan 12, 2008 4:07 pm Post subject: |
Had exactly the same problem (following updating this morning) and was just about to ask this very question when I saw this thread so a big thank you to Andy for the advice which has worked perfectly! |
Chieron Occasional Visitor
Posted: Sat Jan 12, 2008 4:59 pm Post subject: |
I also had the same problem following an update yesterday, and a reset has now cured it for me as well ... Thank you folks. |
