vizzair Occasional Visitor
Posted: Sun Dec 23, 2007 1:43 am Post subject: Speed Alert on a 970-T (UK) |
I have just got the 970 and i do like it, but I find the overspeed warning you get could do to be adjustable.
The 30 MPH warning only sounds when you hit 40MPH ( far to late ) I would like to be able to adjust this to something like 35 or less, but I cannot find anyway to do this .
Are these limits fixed, or is there some way to "tweak" them ? |
Gee-Pee Lifetime Member
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Sun Dec 30, 2007 9:25 am Post subject: Re: Speed Alert on a 970-T (UK) |
vizzair wrote: | Hi,
Just got mine before Christmas and gave it a good run to Switzerland and back. I have found the speed warnings VERY accurate but the voice warning very annoying so I have turned it off. I know that this probably means that I am going one or two KM/MPH above the speed limit briefly but I do keep an eye on it.
I wonder if you are looking at your speedometer or the speed on the 970 because they will be different. Your speedometer is always about 10% over the actual speed that you are travelling whereas the GPS indicated speed should be very accurate. _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Allan_whoops Frequent Visitor
Posted: Tue Jan 08, 2008 4:30 pm Post subject: |
Stupid question, I know. How do you switch off the sound of the warning without switching off all sounds? |
BigPerk Frequent Visitor
Joined: Sep 06, 2006 Posts: 1618 Location: East Hertfordshire
Posted: Tue Jan 08, 2008 6:05 pm Post subject: |
I think Security Configuration screen is what you need. See page 41 on V7 Manual for 1 way to get to it, in Navigation Mode - click on main access button (bottom right), then the 123 icon then the ! icon. _________________ David
(Navigon 70 Live, Nuvi 360) |
B_G Occasional Visitor
Joined: Sep 16, 2007 Posts: 20 Location: N ~51.5958 W ~0.3341
Posted: Tue Jan 08, 2008 6:12 pm Post subject: |
Allan_whoops wrote: | How do you switch off the sound of the warning without switching off all sounds? |
Hi !
You need to be in "Guidance" mode. Hit the little menu harrow on the bottom right, then "Guidance Options" (the little button with a green red & blue dots), then select "Security Configuration" and it's all there. _________________ VM X-970T Europe V7 |
Posted: Wed Jan 09, 2008 8:39 am Post subject: |
I was wondering if you could get a visual warning but no sound. It doesn't have the limit for all roads so there has been an assumption about speed limits. For example it warns me that I am exceeding 30 in a 40 limit. The idea is good but execution is patchy. |
Posted: Wed Jan 09, 2008 10:04 am Post subject: |
There doesn't appear to be the option to turn off the sound (or icon) only on the VM cameras. However, where you install the PGPSW ones (stored as POIs), you CAN set sound/visual separately as you wish, as with other POIs.
There seem to be two alerts; one is for the cameras (and there seems to be a question with some people whether the alarm is set to continental values rather than UK and going off too early) - the other is the speed alert which is based on assumed speed limits for the type of road (which also may not be set for UK). Unfortunately at the moment the values are not adjustable in Version 7, whereas from the Version 6 manual it seems that they were before. _________________ David
Posted: Wed Jan 09, 2008 11:47 am Post subject: |
BigPerk wrote: | There doesn't appear to be the option to turn off the sound (or icon) only on the VM cameras. However, where you install the PGPSW ones (stored as POIs), you CAN set sound/visual separately as you wish, as with other POIs.
There seem to be two alerts; one is for the cameras (and there seems to be a question with some people whether the alarm is set to continental values rather than UK and going off too early) - the other is the speed alert which is based on assumed speed limits for the type of road (which also may not be set for UK). Unfortunately at the moment the values are not adjustable in Version 7, whereas from the Version 6 manual it seems that they were before. |
Hi David I agree with you but with some reservation. It does seem that there is no option to turn off sound and retain the visual speed camera alert but I find the various settings on this device very confusing after using the Navman with it's very easy navigation to all the various settings, for some years. I'm also not sure that the speed alerts are assumed speed limits as my device does seem to give the alert at the start of posted speed limits giving the impression that they are programmed into the device.
My other annoyance is that the speed camera alert is given far too early at 1Km and then frequently up to the camera and is not adjustable. When I get up the nerve, I will install the PGPSW camera POIs and see if I can turn off the VM installed ones (don't like the very small icons on the VM either)
Having said that, the navigation so far has been great and I like the Motorway option. It's a balance thing, isn't it...
Graham _________________ Gee-Pee
