Pocket GPS World :: View topic - Help. One XL wont switch on.
allosunshine
PostPosted: Sun Jan 06, 2008 10:41 am    Post subject: Help. One XL wont switch on. Reply with quote
Is my TomTom knackered?? It won't switch on unless power is supplied to it. The battery is fully charged cos when I unplug it from me PC after switching it on and check the battery it's full. I did let the battery run flat but it should be alright now its charged.
LesP2008
PostPosted: Sun Jan 06, 2008 11:19 am    Post subject: Reply with quote
er... have you pressed the reset button?
chippy1965
PostPosted: Sun Jan 06, 2008 12:11 pm    Post subject: Reply with quote
I had exactly the same problem after pressing the reset it was OK.
After a further bit of trial it seems that after you click on the disconnect button in the home software you need to let the XL reboot to the screen where it comes up with "Do you want to connect to computer" and press the no option. It has worked fine if I remember to do that every time.
biker1
PostPosted: Mon Jan 07, 2008 8:21 pm    Post subject: XL Reply with quote
It's mentioned a couple of times in the forum...Remove SD card and keep the reset button pressed for 15 seconds, replace SD card and switch on, should work now.
What car in front???
We won it 5 times, We won it 5 times.
In Istanbul, We won it 5 times.
Football Capital of the World.
allosunshine
PostPosted: Mon Jan 07, 2008 9:38 pm    Post subject: Reply with quote
Cheers guys, suddenly started turning itself on, think it just had a little brain fart. Thanks again though.
22.124 (26 Dec 24)
