Pocket GPS World :: View topic - “Turn Bluetooth On” with….
hogbreath
PostPosted: Sun Apr 18, 2004 7:04 pm    Post subject: “Turn Bluetooth On” with…. Reply with quote
Is it possible to setup button1 to switch Bluetooth on (not BT Manager).
why?
Would mean you don’t have to use the stylus when setting off, button1 to start BT, button2 for CheckPOInt, when activated button1 then set to Navigate home in ttn.
Probably dreaming as I suspect the answer is no! Wink
Pete
PostPosted: Mon Apr 19, 2004 12:37 am    Post subject: Reply with quote
This is not something you can do with standard Windows tools - but I am pretty sure with a bit of programming such a switch could be done. What's your hardware, and what's your BTM version?
hogbreath
PostPosted: Tue Apr 20, 2004 6:51 pm    Post subject: Reply with quote
Just recently upgraded to the latest rom release ver 1.10
2210/PPC 2003/BT Ver 1.4.1 Build 60
Pete Smile
PostPosted: Fri Apr 23, 2004 5:56 pm    Post subject: Reply with quote
I don't have any 2003 devices so I can't test it but the below code should do the trick
Code:
#include "stdafx.h"
#include "bthapi.h"
int WINAPI WinMain(   HINSTANCE hInstance,
               HINSTANCE hPrevInstance,
               LPTSTR    lpCmdLine,
               int       nCmdShow)
DWORD * pdwMode;
   BthGetMode(pdwMode);
   if(pdwMode == BTH_POWER_OFF)
      BthSetMode(BTH_DISCOVERABLE);
   else
      BthSetMode(BTH_POWER_OFF);
   return 0;
hogbreath
PostPosted: Fri Apr 23, 2004 9:41 pm    Post subject: Reply with quote
Lutz, many thanks, hope i can return the work you've done.
How do i turn the code into an exe prog, assuming this is going into the start menu 8O
Pete
PostPosted: Fri Apr 23, 2004 10:06 pm    Post subject: Reply with quote
You will need to find someone with eVC++ 4.0 and the PocketPC 2003 SDK to compile the code into an .exe file for the ARM platform. Anyone volunteering?
In the meantime I will check if I can come up with a more generic solution (one that works on Pocket PC 2002 as well).
hogbreath
PostPosted: Sat Apr 24, 2004 4:52 pm    Post subject: Reply with quote
Anyone else think this is worth having, other than Lutz & myself
Pete Me Me Me
bagmans911
PostPosted: Thu May 06, 2004 2:39 pm    Post subject: Reply with quote
I have an Ipaq 3970 on 2002, would love a shortcut to a button for BT on, it is a pain in the proverbial having to stylus turn on BT, then button for Checkpoint. Any ideas for a Win 2002 user?
matt_e
PostPosted: Thu May 06, 2004 3:40 pm    Post subject: Reply with quote
I also agree this would be useful
PostPosted: Thu May 06, 2004 4:25 pm    Post subject: Reply with quote
I learned that I need the WidComm SDK for that. I am not even sure it is openly available. If anyone has information on that I'll be happy to code this little proggie.
MrT
PostPosted: Fri May 07, 2004 7:05 am    Post subject: Reply with quote
Why not just leave bluetooth turned on?
kartracer
PostPosted: Fri May 07, 2004 11:53 am    Post subject: Reply with quote
I submitted a reply to this thread a couple of weeks ago, but it seems to have vanished!
The solution I use to do this is ButtonMax from PocketMax:
http://www.pocketmax.net/buttonMax.htm
It allows you to record macros which can then be played back by pressing one of the buttons. My own macro to toggle bluetooth on/off is activated by double-clicking button 3.
Mark R Penn
PostPosted: Fri May 07, 2004 1:46 pm    Post subject: Reply with quote
Your reply WAS there - I saw it and tried it! I can't see why it would have been deleted.
Anyway, I couldn't get ButtonMax to work - I recorded macros, but they simply didn't run Crying or Very sad
What PPC do you have?
kartracer
PostPosted: Fri May 07, 2004 1:51 pm    Post subject: Reply with quote
I use an iPAQ 5550.
Sorry to hear ButtonMax didn't work for you. It's a good job you get to try it for 30 days before paying for it.
PostPosted: Fri May 07, 2004 2:13 pm    Post subject: Reply with quote
Recording and playing back macros is very subtle, especially on the PocketPC. It requires very lew level communication deep inside the kernel (SendMessage etc). Maybe one of your other programs is intercepting these messages (a taskbar utility for example)
22.062 (12 Jun 24)
