andy-c1 Lifetime Member
Joined: Feb 05, 2005 Posts: 1039 Location: East Sussex
Posted: Fri Jan 04, 2008 9:03 am Post subject: new poi catergory |
I was bored teh other day so made a new poi group on my tomtom ,but when i tried to view them after converting there is just an empty file ,yet if i show them up on tomtom they are there ,it's never happened to me before and it always worked ..... any ideas please _________________ TomTom 5001 |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Fri Jan 04, 2008 10:07 am Post subject: Re: new poi catergory |
andy-c1 wrote: | I was bored teh other day so made a new poi group on my tomtom ,but when i tried to view them after converting there is just an empty file | Could you explain what you did. It might give some idea of the steps you took, especially the converting part.
I suspect that what is happening is that you tried to change the OV2 File with a 3rd Party App.
If so this causes problems because TT has changed the way POIs are created on Devices. From memory they are using a Type 100 OV2, whereas most externally created Files are using Type 0, 1, 2 or 3 OV2 Format.
Not all apps can read the new Format.
All I can say is ..... How helpful is that TT? NOT _________________ Richard
Posted: Sat Jan 05, 2008 12:23 am Post subject: |
did it on my tomtom via add poi find it on the map and added poi's then wanted to open it with dump ov2 but there was nothing inside the page under notebook ,when there should have been everything i added from the tt _________________ TomTom 5001 |
Posted: Sat Jan 05, 2008 12:26 am Post subject: |
yep it was _________________ TomTom 5001
Andy_P Pocket GPS Moderator
Posted: Sat Jan 05, 2008 12:47 am Post subject: |
I guess your last post was meant to go in the other topic about a Schools POI?
Back to your problem...
I can't remember what DumpPOI does, but you probably don't need it...
If you make the POIs on the TomTom itself, then they are automatically made into a standard ov2 file, which can be exported just by copying the file from your TomTom's map folder.
That ov2 file is already compatible with several brands of satnav, and most of the others use "csv".
You can use POI Edit to view your files and convert to csv (or several other formats too). |
Posted: Sat Jan 05, 2008 6:32 am Post subject: |
Andy_P2002 wrote: | You can use POI Edit to view your files and convert to csv (or several other formats too). | As far as I know POIEdit is the only program that can open the OV2 Files of Type 064H.
Dumpov2 was only designed for 0 - 3 Types. _________________ Richard
Posted: Sat Jan 05, 2008 6:51 pm Post subject: |
Is there a write up anywhere of all the ov2 "types" and the differences between them. I thought I read that TT now used "type 100", not heard of type 064H (or is that 100 in hex?!) |
Posted: Sat Jan 05, 2008 7:29 pm Post subject: |
Andy_P2002 wrote: | I thought I read that TT now used "type 100", not heard of type 064H (or is that 100 in hex?!) | _________________ Richard
Posted: Sat Jan 05, 2008 7:38 pm Post subject: |
Andy_P2002 wrote: | Is there a write up anywhere of all the ov2 "types" and the differences between them. | Found it.
http://www.licour.com/gps/poi_format/poi_file_format.html
It's not a complete list of types and only shows those that were in existent when the page was written.
TT just made things a bit more complicated. Possibly to make it difficult for the likes of thee and me. _________________ Richard
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Sat Jan 05, 2008 7:42 pm Post subject: |
So far I have seen OV2 files with the following record types in them:
0= Deleted record
1= Skipper record (defines areas containing POIs)
2= Location and text description
3= Location, Text description, Unique ID, Extra data (unknown)
4= Encoded location with no description
5= Encoded location with short numeric description
6= Encoded location with long numeric description
7= Encoded location and text description
8= Encoded location and description compressed using lookup table
9= Encoded location and description compressed using binary tree
10= Encoded location and description compressed using character translation table
12= Encoded location and description compressed using 5 bit encoding
15= Same as type 2
20= Same as type 4
21= Same as type 5
22= Same as type 6
23= Same as type 7
24= Same as type 8
25= Same as type 9
26= Same as type 10
28= Same as type 12
100= Header record with unknown content
and yes 100 decimal = 064H |
Posted: Sat Jan 05, 2008 11:45 pm Post subject: |
I thought i should check another group i have started adding to, wimpy and all the poi's I've added there are there ,i tried manually changing my other poi and my poi's ended up way off course ....... _________________ TomTom 5001 |
Posted: Sun Jan 06, 2008 12:55 am Post subject: |
ok i finally got them converted ..... all i need is for some kind soul to make a picture with the words "COOK" anyone .. from cook.co.uk
I've tried to make 1 but it's awful _________________ TomTom 5001 |
Posted: Thu Jan 10, 2008 3:16 pm Post subject: |
As TT have now taken to blaming the the PGPSW speed cam files when v7 software repeatedly looses all the 'warn when near' settings, are there any plans for PGPSW to re-jig them into TT's preferred new format?
Have TT even given developers any clues about the new format? (I doubt it!)
Is anyone beavering away to make a utility to convert between the different types? |
Posted: Thu Jan 10, 2008 8:46 pm Post subject: |
I have yet to find anyone who has decoded the type 100 (064H) record.
If I delete the record from the POI file I can detect no difference on the tomtom.
On the tomtom, if you create a new POI category with no entries the file contains a type 100 record. If you then create another POI category it gets a type 100 record containing different data. The data does not seem to relate to the category name or the icon used for the category.
I am currently at a loss as to the purpose of this record. |
Posted: Thu Jan 10, 2008 9:54 pm Post subject: |
Andy_P2002 wrote: | Is anyone beavering away to make a utility to convert between the different types? | If you Open the File in POIEdit, and then Save it, it will Save it as a Type 1 ..... overwriting the Type 100. _________________ Richard
