Andy_P Pocket GPS Moderator
Posted: Tue Jan 01, 2008 3:43 pm Post subject: Re: TomTom One v1 with map 6.05 - worth updating? |
jem16 wrote: |
Can you tell me if the A726 meets the M77 and continues down onto the East Kilbride road? When I drive this road, TomTom thinks I'm driving over fields! |
It does meet it. It then goes through lots of name changes but eventually becomes the E.Kilbride Road.
Does this help?
(Sorry if you can't see the pictures, all the edits were to change the name of the jpg file as I'm having trouble with uploading pictures to my ISP. They look like they are there, but next time I look they've gone again).
jem16 Occasional Visitor
Posted: Tue Jan 01, 2008 3:47 pm Post subject: |
Oldboy wrote: | jem16 wrote: | I have made a backup of my original card via Home. What's better about doing it via Explorer. | 1. You are in control of what you Backup.
2. When HOME changes versions it's quite possible the newer version won't read the Older Backup. As has happened in going from 1.5 to 2.1 |
Ah I see. I never tried looking for the old backup once I had updated Home to 2.1
Quote: | jem16 wrote: | Can I, if I want to, just keep one map on a time and keep the other on my PC? | Yes. You can ring the changes as you want.
If you Install it first, then Back it up to the PC, It's simply a case of Copy/Paste, rather than going through the Install process. |
Are you saying that i should install both maps first. Then backup to the PC and remove or add whichever one I want to have on at that time?
Quote: | Junction 3 of the M77 is the access to the A726, which continues into East Kilbride. |
Thansk - that would make a difference. Which map do you have as Andy seems to not have what I'm expecting to see. |
Posted: Tue Jan 01, 2008 3:57 pm Post subject: Re: TomTom One v1 with map 6.05 - worth updating? |
[quote="Andy_P2002"] jem16 wrote: |
Does this help?
It does help but that's still an older version of the A726.
This is what it looks like now.
http://www.multimap.com/maps/#t=l&map=55.75696,-4.35084|17|4&loc=GB:55.77226:-4.22518:17| |
Posted: Tue Jan 01, 2008 4:38 pm Post subject: |
Looks like a pretty new bypass.
If you look t the aerial photo view, it's dated 2006 and that whole junction is a building site!
I'll be surprised if it's made it onto the latest maps from TeleAtlas yet. |
Posted: Tue Jan 01, 2008 5:06 pm Post subject: |
It's been open since around the end of 2006.
Thanks anyway. |
Oldboy Pocket GPS Moderator
Posted: Tue Jan 01, 2008 6:34 pm Post subject: |
This is Junction 5 of the M77. According to the 710 Map there are 2 Junctions where the A726 joins the M77.
This is the one you are referring to.
jem16 wrote: | Are you saying that i should install both maps first. Then backup to the PC and remove or add whichever one I want to have on at that time? | It doesn't matter if you do them singularly or together, as long as the Maps are Backed up. _________________ Richard
Posted: Tue Jan 01, 2008 10:57 pm Post subject: |
Oldboy wrote: | This is Junction 5 of the M77. According to the 710 Map there are 2 Junctions where the A726 joins the M77.
This is the one you are referring to. |
Yes that's the one I'm after - thanks.
I had forgotten that the original A726 went from East Kilbride through Busby & Clarkston and eventually joined the A77 ( now M77 ) at Darnley. Why they have also named the bypass road which goes from just outside East Kilbride to meet up with the A77 also the A726 I don't quite understand either. No wonder people get confused.
Quote: | jem16 wrote: | Are you saying that i should install both maps first. Then backup to the PC and remove or add whichever one I want to have on at that time? | It doesn't matter if you do them singularly or together, as long as the Maps are Backed up. |
Great thanks. |
