Pocket GPS World :: View topic - Type of SD card for NUVI 300
Zondaf
PostPosted: Mon Dec 03, 2007 2:08 am    Post subject: Type of SD card for NUVI 300 Reply with quote
What type of SD card do I need to buy to work in a Garmin Nuvi 300? I'm looking at getting either 2 or 4 Gig size.
crazyfingers
PostPosted: Mon Dec 03, 2007 4:37 pm    Post subject: Re: Type of SD card for NUVI 300 Reply with quote
You don't necessarily NEED an SD card at all if all you will use it for is navigation.
If you want to use it to play music or play photos or whatever, you get an SD card with as much space as you want.
Not sure what information you are looking for.
philpugh
PostPosted: Tue Dec 04, 2007 3:38 pm    Post subject: Reply with quote
Careful... Not sure the 300 will take the SDHC cards that the higher capaciies (4GB +) sometimes use.
Phil
Zondaf
PostPosted: Wed Dec 12, 2007 12:26 am    Post subject: Reply with quote
Yeah, that's what I was confused about. I looked on a few sites and there seems to be lots of different types, such as 'mini', 'micro' and 'high speed' - which can I use ? All the manual says is that u can only use upto 2 Gig.
bellymungo
PostPosted: Wed Dec 12, 2007 11:45 am    Post subject: sd card Reply with quote
i have a nuvi 360. mmc cards dont work, i use an integral high speed 2 gb sd card as this the highest recommended by garmin, not tried sdhc card yet, also i deleted any unnecessary stuff off my nuvi ie languages as this gives extra space for music.
hope this helps
Zondaf
PostPosted: Sun Dec 16, 2007 1:33 am    Post subject: Re: sd card Reply with quote
hope this helps
What card have u got in yours - Mini or Micro ?
Zondaf
PostPosted: Mon Dec 31, 2007 2:21 am    Post subject: Reply with quote
Just 2 clarify, does the NUVI 300 takes a standard SD card - not a Micro or Mini one?
And it can be a high speed one?
PostPosted: Mon Dec 31, 2007 6:42 am    Post subject: Reply with quote
A standard size 2GB SD card will be fine for use in your device, if you can get a high speed one say 150x or even 166x even better although the high speed is not all that necessary for playing music from - Mike
