Pocket GPS World :: View topic - Unable to activate bluetooth on T3
gavina
PostPosted: Thu Apr 08, 2004 3:39 pm    Post subject: Unable to activate bluetooth on T3 Reply with quote
Can anyone help with a Mapsonic crashing problem?
If I go into GPS Parameters from either the file menu or from Navigation mode then as soon as I select 'bluetooth' and 'activate' the program crashes and the Palm has to be reset. Sad
It is a Tungsten T3 and it has had the T3 patches applied to make use of the drop down screen.
I would much appreciate any advice or guidance you can offer.
Mspn
PostPosted: Sat Apr 10, 2004 12:58 am    Post subject: Delete BT device cache Reply with quote
The solution is to delete the Bluetooth device cache from your Palm. You will lose all trusted devices that you have paired with, but after doing this Mapsonic will let you activate bluetooth and you can pair other devices after that, Mapsonic still works.
To delete the cache, select 'App' menu from tungstens main screen. Then select 'delete' and 'Bluetooth device cache' and delete it.
It's a pain, but it works.
Thumbs Up
gavina
PostPosted: Mon Apr 19, 2004 9:43 am    Post subject: Reply with quote
Many thanks, Mspn Great stuff :D
G11YMC
PostPosted: Wed Feb 16, 2005 5:48 pm    Post subject: Reply with quote
:D MSPN - can I also say a big thanks.... sorted my problem there!
