rob1951 Occasional Visitor
Posted: Wed Dec 26, 2007 9:34 am Post subject: tomtom one won't switch on |
Well it will but only if I unplug and reinsert the memory card first!
The switch isn't defective 'cos I still have to use that to turn on and off.
I don't understand - is the power-on process software mediated in some way? I guess it might be as you normally have to hold the button down for a few second before it activates.
Battery is fully charged. Memory card connections look clean, no other problems with the device. Got latest software updates from tomtom.
Last change to system was to add some POIs from this site. |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Wed Dec 26, 2007 9:37 am Post subject: |
Have you tried pressing the reset button with a paperclip? |
phillmobile Occasional Visitor
Posted: Fri Dec 28, 2007 3:24 am Post subject: tom tom one xl |
hi i have a tom tom one xl and it worked fine until i updated to version 7.162 and since i have done this my tom tom refuses to switch on when not plugged in to 12v cable unless i do some kind of witch dance and mess about with the sd card and power button for a few hours, but if its plugged in to 12v cable i comes staright on, now in the menu there is a option to only turn on if indeed plugged in to cable but this is clearly un ticked, and it only did this after upgrading is very annoying |
Andy_P Pocket GPS Moderator
Posted: Fri Dec 28, 2007 4:44 am Post subject: Re: tom tom one xl |
phillmobile wrote: | hi i have a tom tom one xl and it worked fine until i updated to version 7.162 {snip} it only did this after upgrading is very annoying |
Then why not go back to a previous version? Either by using a backup (which you should always make before updating software for this very reason) or by finding a previous version archived by one of the regulars here. |
Snudge Lifetime Member
Joined: Aug 22, 2007 Posts: 212 Location: Peterborough
Posted: Fri Dec 28, 2007 12:25 pm Post subject: |
A similar problem was discussed in this thread. Also, I recently swapped my current card on One XL with the original card supplied with the unit to check a map detail on previous map and found that when I swapped back to the new card which had app 7.162 it would not start unless plugged into usb cable but a full reset fixed it. |
46jimbo Regular Visitor
Posted: Fri Dec 28, 2007 3:39 pm Post subject: |
A paperclip reset fixed it for me. |
tilyymolly Occasional Visitor
Posted: Sat Dec 29, 2007 1:12 pm Post subject: |
Snudge wrote: | A similar problem was discussed in this thread. Also, I recently swapped my current card on One XL with the original card supplied with the unit to check a map detail on previous map and found that when I swapped back to the new card which had app 7.162 it would not start unless plugged into usb cable but a full reset fixed it. |
This has been bugging me for a few weeks now. It would only power on when I removed the SD card. A full reset fixed it. Thanks Snudge |
