Pocket GPS World :: View topic - NavTek 855
NavTek 855
P
PostPosted: Mon Dec 24, 2007 12:51 pm    Post subject: NavTek 855 Reply with quote
Hi could some one help please? I have recently purchased a NavTek 855 Sat Nav
Off ebay. First impressions is good! The only problem is that the standard speed cams POI that came with the unit does not show on the maps even though I have checked the poi settings and all are enabled. The maps do show the the other POI. I then gave up with
the standard poi and downloaded the ones from Pocketgps for Route66 but they do not
Show in the poi menu. The version I am running is route 66 Ver (7.0.2091)
Can some one please help me!!
PostPosted: Mon Dec 24, 2007 1:09 pm    Post subject: Reply with quote
Welcome to the forum, Have you had a read through This Thread which details configuring the Speed Camera files on the Route 66 software, this does of course assume you are trying to install the Pocket GPS World Speed Camera Database - Mike
P
PostPosted: Thu Dec 27, 2007 10:36 am    Post subject: NavTek 855 Reply with quote
Hi there,
Thanks for you reply. It is the Pocket world database I am trying to install and I have followed the thread.
None of the POI in the pois Britain folder show on the map or in the POI management in route 66.
Help please!
PostPosted: Thu Dec 27, 2007 10:50 am    Post subject: Reply with quote
Can you confirm the spelling of the folder path mobile device/ Storage Card/ POIS/ Britain and make sure your folders etc are exactly the same in terms of upercase etc.
Next can you tell me the contents of the POIS? Britain folder, i.e. what is the name of the files contained within this folder, just two or three files will suffice rather than listing them all - Mike
P
PostPosted: Thu Dec 27, 2007 5:13 pm    Post subject: Reply with quote
Hi got it Woking!! I had a look in the shell.ini file at the route it was set to(\sdmmc\route66n7\test.exe) I changed
it to (\sdmmc\route66n7\ROUTE66N7.exe) and Bingo!! it all works. Thanks for you help!
benleb
PostPosted: Wed Mar 05, 2008 11:48 am    Post subject: Reply with quote
I'm having problems finding out where you can get updating downloads for the Navtek 855. Navteq referred me to the manufacturers but who are the manufacturers?
PostPosted: Wed Mar 05, 2008 2:07 pm    Post subject: Reply with quote
Welcome to the forum, is the unit you have actually running Route 66 software? also can you be more specific as to what you want to update:
Maps, Application software, POI files etc - Mike
22.064 (26 Jun 24)
