Pocket GPS World :: View topic - 520 will not restart folowing restore.
jm202067
PostPosted: Wed Dec 26, 2007 2:36 pm    Post subject: 520 will not restart folowing restore. Reply with quote
I have just done a restore on my 520 and now it just freezes on the startup screen. I don't get a red cross on the screen just the wallpaper startup screen. I have tried holding the reset in several times for 30 seconds + without sucess.
Oldboy
PostPosted: Wed Dec 26, 2007 4:29 pm    Post subject: Reply with quote
To give us some idea of what is happening, why was it necessary for you to do a restore?
How did you do the Restore? Home or Explorer.
Have you got an SD Card in the Slot? If so, try it with the Card out.
jm202067
PostPosted: Wed Dec 26, 2007 5:41 pm    Post subject: Reply with quote
I restored it using Home 2 and have tried removing the memory card but still can't get past the wallpaper startup screen.
Oldboy
PostPosted: Wed Dec 26, 2007 6:22 pm    Post subject: Reply with quote
What was the problem that required you to do a Restore?
Do you have a Software Update in the HOME Download Folder?
Have a look at This Post. It sounds like you have corrupt data somewhere.
It is something that we always stress here - do a Full Backup using Windows Explorer. At least you have control over what is Saved.
Do one now even if the Device is not working, to make sure that ALL the data is secure.
jm202067
PostPosted: Wed Dec 26, 2007 6:32 pm    Post subject: Reply with quote
I can't access the files on the Tomtom because when i connect it to my pc i am not getting the screen on theTomtom that asks if i want to connect it to the pc. Just the startup wallpaper is permanently showing.
jm202067
PostPosted: Wed Dec 26, 2007 6:42 pm    Post subject: Reply with quote
Have got it to show up on my pc by pressing the reset button then putting it in the cradle to switch on. Have done a restore but still won't get past the wallpaper screen.
Oldboy
PostPosted: Wed Dec 26, 2007 6:44 pm    Post subject: Reply with quote
OK.
If you do a 30 second Reset with the Device switched on, does it re-boot, or do you have to switch it on again?
jm202067
PostPosted: Wed Dec 26, 2007 10:11 pm    Post subject: Reply with quote
I have to switch it on again and it just boots to the wallpaper screen.
Oldboy
PostPosted: Wed Dec 26, 2007 11:33 pm    Post subject: Reply with quote
If you do that does HOME see the Device?
If so, have you got the Software in the program sub-folder of the HOME Download Folder.
By default it is C:\Documents and Settings\Owner\My Documents\TomTom HOME\Downloads\program
You should have a Folder in there with the name TomTomApplicationfor.... or similar.
If you have, you need to follow the directions in This Post. Ignore the first bit about how to connect your Device to PC and do it the way you did above.
You will need to delete the Files, Not the Folders with Explorer, and then re-install the software with HOME using Add Maps, voices, etc. Then Items on my computer.
Remember to use Safely Remove Hardware before unplugging the USB Connector.
jm202067
PostPosted: Thu Dec 27, 2007 11:28 pm    Post subject: Reply with quote
I have tried to restore the files but my restore stops part way through when reinstalling them.
jm202067
PostPosted: Fri Dec 28, 2007 3:55 pm    Post subject: Reply with quote
Have finally brought it back to life by deleting everything in the Tomtom's memory and then doing a restore. Strangely just doing a restore without clearing the Tomtom's memory didn't work for some reason. A clean restore did the trick. Thanks for everyones help. Very Happy
22.064 (26 Jun 24)
