Pocket GPS World :: View topic - TT520
TT520
nimh999
PostPosted: Sun Dec 23, 2007 8:30 pm    Post subject: TT520 Reply with quote
Which camera database is used for TT520 because I can't see which one is suitable?
PostPosted: Sun Dec 23, 2007 8:32 pm    Post subject: Reply with quote
TomTom ov2 just download it and unzip the download, copy the files straight to your Map Folder on the device - Mike
nimh999
PostPosted: Sun Dec 23, 2007 8:38 pm    Post subject: Reply with quote
But all the TT databases are OV2.
Am I missing something?
PaulB2005
PostPosted: Sun Dec 23, 2007 8:41 pm    Post subject: Reply with quote
Can you clarify the problem?
Surely if you select TomTom OV2 then hit continue you can select the format you want from the next list.
If you want to know what the different formats are they are listed to the right of the selection list.
What are the available downloads?
The downloads vary dependant on the SatNav system you use. Not all types are available for each system.
Consolidated by type: Contains one file for each type of speed camera.
Single File: Contains all the speed cameras in a single file irrespective of type.
Speed Zoned: Contains the speed cameras in individual files for each speed limit and each camera type.
nimh999
PostPosted: Sun Dec 23, 2007 8:48 pm    Post subject: Reply with quote
If I go to the download choose Speed Camera download page this is what I see when I scroll down to the Tom Tom section.
TomTom CityMaps,
RoutePlanner No
TomTom Go 910 Yes TomTom OV2 / TomTom Home OV2 Click Here
TomTom Go series,
One series,
Rider Yes TomTom OV2 / TomTom Home OV2 Click Here
TomTom Navigator 1,2,3
HP Navigation Kit,
Palm,
Mobile
TomTom Navigator 5 & 6 on Pocket PC Yes TomTom OV2 / TomTom Home OV2
Obviously I am looking for a section which says Tom Tom 520 Click Here.
But seeing as Mike Alder has suggested just choose an OV2 file and they are all OV2 files I obviously don't want to choose the wrong download.
So am I missing something?
PaulB2005
PostPosted: Sun Dec 23, 2007 8:55 pm    Post subject: Reply with quote
Every single model on the market is NOT listed!!!
All you are looking at is a table of information about which database is compatible with which line of Sat Navs.
You need TomTom Go range for your TomTom Go 520, which is listed under Go 910 and above One Series.
Here is the information you need - Click Here
Once you have subscribed you can download the database. You need to select TomTom OV2 then the format you want to use.
nimh999
PostPosted: Sun Dec 23, 2007 9:10 pm    Post subject: Reply with quote
[quote="PaulB2005"]
Yes but I wasn't to know that.
Thank you very much for your help.
nimh999
PostPosted: Sun Dec 23, 2007 9:31 pm    Post subject: Reply with quote
Once again thanks for your help
but!!!
Obviously I ain't no expert, but if it was so obvious that every model was not going to be listed, and assuming every OV2 database is compatible with Tom Tom's then wouldn't it be more obvious just to list Tom Tom once so that you just chose Tom Tom rather than the half a dozen options?
PaulB2005
PostPosted: Sun Dec 23, 2007 9:33 pm    Post subject: Reply with quote
The list you are looking at is a list of compatibility options and instructions pages. Look at the Click Here links in the right hand column. Each one points to a different set of instructions hence the multiple options.
If you have a 910 you use these instructions
If you have a GO, One or Rider you use these instructions
etc
nimh999
PostPosted: Sun Dec 23, 2007 9:38 pm    Post subject: Reply with quote
I think this is finally, but just to check.
I choose the TT910 option for a TT520?
PaulB2005
PostPosted: Sun Dec 23, 2007 9:43 pm    Post subject: Reply with quote
No. Shocked
As stated above, and because you have a Go 520, you select the "GO, One or Rider" instructions.
Quote from above
PostPosted: Sun Dec 23, 2007 10:52 pm    Post subject: Reply with quote
No. Shocked
In actual fact, because the 520 has TTS capability, the instructions for the 910 would be correct if using the TTS for warnings.
PostPosted: Sun Dec 23, 2007 10:53 pm    Post subject: Reply with quote
Sorry Paul, but I think you are
a. confusing the guy , and
b. wrong.
The reason there are different instructions for the 910 are because it was re-written to add instructions for the text to speech abilities.
As the 520, 720 and 920 models also have text to speech capabilities, the most relevant instructions ARE the ones for the 910.
The compatibility table needs updating to reflect this.
PaulB2005
PostPosted: Sun Dec 23, 2007 11:16 pm    Post subject: Reply with quote
Not sure where. Tried to be as specific as possible.
b. wrong.
In the light of what Oldboy and you have said then yes, i accept that.
I tried to help as i'm not that knowledable on the TT side of things (does it show? Embarassed ).
nimh999
PostPosted: Mon Dec 24, 2007 12:17 am    Post subject: Reply with quote
Ain't no problem because we got there in the end.
Once again, thanks for your help.
22.063 (19 Jun 24)
