daznsaz Occasional Visitor
Posted: Wed Dec 19, 2007 7:30 am Post subject: Recording your own warnings tt910 |
I have a TT910, I was setting up my speed camera and poi warnings using home and noticed that there was an option for recording your own warnings. I recorded a couple of speed camera warnings that recorded and playbacked fine but on the road i just get the normal bing bong.
Does this function work on the 910?? |
Andy_P Pocket GPS Moderator
Posted: Wed Dec 19, 2007 12:33 pm Post subject: |
Your recordings will get placed in a folder called "sounds".
Assuming you are using the PGPSW camera data:
When you go to the "warn when near" setup for EACH of your POI categories you should get to the normal sound effects page with cows bongs etc.
At the bottom of the list you should find your recordings which you can select in the normal way.
If you are using TT's OWN camera warnings, it is done in the "Plus Services" menu, but the sound selection is similar. |
Scotty-uk Regular Visitor
Joined: Dec 24, 2006 Posts: 61 Location: J7 M11 (Essex)
Posted: Sat Dec 22, 2007 8:45 am Post subject: |
I also have a 910 and have played around with text to speech messages and all sorts.
I believe the best and easiest way is just to download one of the voice packs from here and you get the perfect warning everytime. |
Posted: Sat Dec 22, 2007 9:49 am Post subject: |
Scotty-uk wrote: | I also have a 910 and have played around with text to speech messages and all sorts.
This isn't so much text to speech, it's where you can record your own voice and have that as your warning. |
Posted: Sat Dec 22, 2007 7:07 pm Post subject: |
So have you got it working now daznsaz? |
Posted: Sat Dec 22, 2007 7:12 pm Post subject: |
Andy_P2002 wrote: | So have you got it working now daznsaz? |
Need to have another play, i want to get my daughter to do the voices i.e "daddy, slow down, camera" that sort of thing. But she has been a bit troublesome the last couple of days, will try tomorrow. |
kevuk Occasional Visitor
Posted: Wed Dec 26, 2007 11:00 pm Post subject: |
daznsaz wrote: | Andy_P2002 wrote: | So have you got it working now daznsaz? |
i think that is a really good idea getting your daughter to do the the voice i bought myself a tomtom 920 today your idea is worth consideration |
Posted: Thu Dec 27, 2007 7:51 am Post subject: |
I have not got this to work 100% yet.
It records fine and plays back fine through tt home simulator, even works doing a demo route.
On the 910 it defaults back to a bong, the .wav file is there but won't test or play if selected.
Anybody got any ideas?? |
Flack Regular Visitor
Posted: Thu Dec 27, 2007 11:45 am Post subject: |
daznsaz wrote: | I have not got this to work 100% yet.
I have the 910 as well and I had a similar problem I found that I could get it to work only if the names matched the file that they where associated with 100%, I had a few post on here and Andyp who replied to some of them with some great tips on how try and get it working he stated that the names did not have to be the same, some have got it working with the names that are different but mine did as yours is doing until I named them the same and all work good now in any mode.
Flack. |
