Pocket GPS World :: View topic - Fortuna BT clipon and Teletype?
Goto page Previous  1, 2
UHF
PostPosted: Fri Apr 16, 2004 10:12 pm    Post subject: Reply with quote
Ibendlin, you should post your finding about TType software.
lbendlin
PostPosted: Sat Apr 17, 2004 12:25 am    Post subject: Reply with quote
Initial investigation shows that indeed the Teletype application not just warns about unrecognized devices but actively disables the GPS as soon as a jacket or CF GPS is detected.
I even see this happening when I connect both a serial GPS and the jacket GPS (which I need for the enclosed storage card slot) - Teletype won't work, not even with the serial GPS. The same serial GPS works fine when the GPS jacket is removed (using a standard PC-Card jacket for the map data)
I'll need to play some more with the registry but initially you may be right - they are short sighted enough to block foreign jackets and CF cards, and only allow third party serial and BT receivers. how weird is that...
Lutz
TomTom/TeleAtlas NAVTEQ
UHF
PostPosted: Mon Apr 19, 2004 6:13 pm    Post subject: Reply with quote
Additionally, the Fortuan BT Clip-on works great with fast fixes.
UHF
PostPosted: Mon Apr 19, 2004 6:17 pm    Post subject: Reply with quote
So, they absoultly need to change thier discription of the word wireless to "sleeve, jacket style, CompacFlash and SDIO GPS receivers" since BT is truely wireless, not a plug-in device.
TeleType does not support NMEA devices which are wireless such as compact flash or jacket style GPSs made by other companies. You need to provide a serial cable from your computer or PDA to make the connection to the GPS receiver's serial cable.
Page 2 of 2
22.064 (26 Jun 24)
