Pocket GPS World :: View topic - nuvi 250 calibration
alvaro
PostPosted: Fri Dec 07, 2007 11:05 pm    Post subject: nuvi 250 calibration Reply with quote
hi i have a nuvi 250 and i find it slightly innacurate, when i approach a turning it tells me to turn just after the turning is there a way of clibrating the screen thanks
PlaneApart
PostPosted: Sat Dec 08, 2007 1:37 pm    Post subject: Reply with quote
I would suggest a "Master Reset" to cure the problem.
Press the top right corner of the screen whilst switching the Nuvi on.
Keep pressing until you get the reset option and press yes.
You'll have to reselect some of your options after, but well worth the effort.
alvaro
PostPosted: Sat Dec 08, 2007 7:13 pm    Post subject: Reply with quote
thanks will try that and report back
alvaro
PostPosted: Sat Dec 08, 2007 7:25 pm    Post subject: Reply with quote
have tried to do master reset like you said holding top right corner but does not seem to do anything , i noticed there is a reset button on bottom of unit will that help .
PlaneApart
PostPosted: Sun Dec 09, 2007 10:51 am    Post subject: Reply with quote
I've got a 310D and the master reset works with that, and I think yours is basically the same.
I suggest you try again, making sure you're pressing the top right corner of the screen as you switch the Nuvi on, and don't stop pressing until you get the reset options. You'll get all the loading screens first, but just keep pressing unti the reset appears.
inspiredron
PostPosted: Sun Dec 09, 2007 5:46 pm    Post subject: Reply with quote
Different models use different corners for hard reset. If top right does not work try the other corners. You may even get into maintenance mode as on the 660. Keep pressing the corner until you get the appropriate message but don't try to push th escreen out of the back of the nuvi! Laughing
graygo
PostPosted: Mon Dec 10, 2007 11:29 pm    Post subject: Reply with quote
Try sliding the power button to the left and hold it there for about 30 seconds, this should allow you to enter calbration mode.
PostPosted: Tue Dec 11, 2007 5:31 pm    Post subject: Reply with quote
graygo wrote:
tat will calibrate the touch screen though, the OP was meaning the map-lag!
PeterSm
PostPosted: Thu Dec 27, 2007 10:45 pm    Post subject: Reply with quote
250(w) uses bottom right, held down when powering on to do a "user" reset. Seems to work ok
22.063 (19 Jun 24)
