Pocket GPS World :: View topic - Safety Camera Database
IVJohnD
PostPosted: Fri Dec 07, 2007 1:25 pm    Post subject: Safety Camera Database Reply with quote
Can anyone help me.
I have just updated all my POI's as previous ones were about 1 year old. All the POI's seem to show up alright, including new ones that I did not have before.
My problem is that none of the PocketGPS speed camera database files show up for selection in Enable/Disable POI's, even though the BMP & OV2 files are in the "Great Britain NavigatorMap" folder with the other POI files.
I am using a HP Pocket PC, with TomTom 5 ver 5.000 (4890) software, the map is Great Britain Navigator Map v 562 and GPS driver v 1.20.
Can you help as to why the Speed Camera POI's are not available to select.
I have run a demo route that passes Speed Camera's that are in the database, but they do not show.
PostPosted: Fri Dec 07, 2007 1:34 pm    Post subject: Reply with quote
How many POI files have you installed? It may be that you have exceeded the physical limit.
IIRC Version 5 has a limit of thirty or thereabouts additional POI files. You can test this by removing all but the speed camera POIs and then seeing if they appear in the enable list.
PostPosted: Fri Dec 07, 2007 3:00 pm    Post subject: Reply with quote
The limit is 39 so if you have more than 39 files carrying the .ov2 file extension that will be your problem - Mike
PostPosted: Fri Dec 07, 2007 6:19 pm    Post subject: Reply with quote
And the software picks the 39 it is going to show you at random. It isn't necessarily the last ones added that get left off.
IVJohnD
PostPosted: Sat Dec 08, 2007 5:56 pm    Post subject: Safety Camera Database Reply with quote
Thank you for the replies.
Problem now solved, with your help.
IVJohnD.
22.094 (25 Sep 24)
