Pocket GPS World :: View topic - After using pocketgpsworld camera updates..
garmin_user
PostPosted: Mon Dec 03, 2007 7:16 pm    Post subject: After using pocketgpsworld camera updates.. Reply with quote
Hi I updated my Garmin Nuvi using the latest database but it is still showing an average speed camera on the A14 orwell bridge which has been gone a few weeks now?.
swing
PostPosted: Mon Dec 03, 2007 9:42 pm    Post subject: Reply with quote
Please go the Speed Camera submission page and submit a report reporting the removal of the camera. If you already have done this - well done! If not, please do this to improve the database for us all.
Please don't be offended if I do not reply to a PM - please ask questions via the forums.
garmin_user
PostPosted: Mon Dec 03, 2007 11:09 pm    Post subject: Reply with quote
Hi, i am new to pocketgpsworld but did have a look & it appears with a cross already so does this mean i need to disable cyclops as even though i am using the latest database cyclops had it on there before my subscription ran out.
swing
PostPosted: Tue Dec 04, 2007 6:04 am    Post subject: Reply with quote
If you still have the Cyclops database alerts turned on, then yes, you'll need to turn them off too.
garmin_user
PostPosted: Tue Dec 04, 2007 7:25 pm    Post subject: Reply with quote
I turned off cyclops which solved this issue but the cameras off here don't come up as fixed? when they are? why is this? as with garmin updates you are made aware you are approaching a fixed camera & not a mobile etc.
PaulB2005
PostPosted: Tue Dec 04, 2007 7:33 pm    Post subject: Reply with quote
Which database did you download? Speed Zoned, Consolidated or Single File?
garmin_user
PostPosted: Tue Dec 04, 2007 8:13 pm    Post subject: Reply with quote
Not sure, which one would tell me if a camera was fixed? single file?
PostPosted: Tue Dec 04, 2007 9:04 pm    Post subject: Reply with quote
you seem to have downloaded a mixture but i'd recommmend Garmin POILoader: 'Speed Zoned' or 'Consolidated by Type'
garmin_user
PostPosted: Tue Dec 04, 2007 10:21 pm    Post subject: Reply with quote
Hi, i do use the poi loader, but i will try what you have suggested.
PostPosted: Tue Dec 04, 2007 10:55 pm    Post subject: Reply with quote
the last download you made (when i checked earlier) was Garmin Other: GPX Wink
garmin_user
PostPosted: Wed Dec 05, 2007 11:08 am    Post subject: Reply with quote
Because that's the file format i saw when exploring the garmin unit, but i have tried a few now.Only thing i am concerned about is that some units have locked up using the updates off this site.
PostPosted: Wed Dec 05, 2007 11:21 am    Post subject: Reply with quote
correction: some units using garmin's faulty firmware have locked up when too many poi's have been loaded onto the unit from ANY source.
if you have the most recent firmware then this is no longer an issue.
garmin_user
PostPosted: Wed Dec 05, 2007 10:23 pm    Post subject: Reply with quote
I have updated the firmware on my garmin rescently so i should be fine, thanks for the info.
swing
PostPosted: Thu Dec 06, 2007 7:57 am    Post subject: Reply with quote
...and it wasn't just PGPSW's fault - I was able to lock up a unit without any PGPSW files onboard by hitting the same fault using only music files.
22.064 (26 Jun 24)
