Fatdave42 Lifetime Member
Posted: Sun Dec 02, 2007 9:06 pm Post subject: 910 will not turn on |
I have got a 910 with out the SD card, and I can not get it to turn on. When i plug in power i get the grean light on, but that is it.
Any idears?
Dave |
Andy_P Pocket GPS Moderator
Posted: Sun Dec 02, 2007 9:49 pm Post subject: |
Have you pressed the reset button inside a tiny hole on the bottom (with a pin)?
After that, try switching it on by holding the on/off button down for at least three to four seconds.
If that doesn't fix it, if you have access to a DC voltmeter, check the voltage on the plug of the EVERY charger you have used. It should be no more than 5 Volts (a standard fault of the car charger is that it goes high output, putting 12 Volts up the TomTom - Boom.
Or you'll get the same result if you accidentally use the WRONG power adapter (for a mobile phone?) that isn't actually 5 V output. |
Posted: Sun Dec 02, 2007 10:01 pm Post subject: |
Connect it to the PC so the green light is on indicating charging and leave it over night in this state, if the battery is very low the hard drive won't spin up and the device will appear dead, give it a decent charge and try again, after this if it still doesn't work it is probably defective - Mike |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Sun Dec 02, 2007 11:31 pm Post subject: |
mikealder wrote: | Connect it to the PC so the green light is on indicating charging | The 910 doesn't USB Charge.
It can be Mains Charged in the Desktop Cradle though.
If you hold it close to your ear, you can hear the Hard Drive spin up. _________________ Richard
TT Via 135 App 12.075: Europe Map v1145 |
