dougttt Occasional Visitor
Posted: Sat Dec 01, 2007 7:44 pm Post subject: tomtom bmp's and ov2's will not paste into ipaq rx5900 |
Beginners woes.........I managed to get the speed camers database into the ipaq last month, but the latest files will not paste into the western europe folder, the paste option just greys out. How can I update?? |
philpugh Lifetime Member
![](modules/Forums/images/avatars/gallery/bass_fret.jpg)
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Wed Dec 05, 2007 3:20 pm Post subject: Re: tomtom bmp's and ov2's will not paste into ipaq rx5900 |
dougttt wrote: | Beginners woes.........I managed to get the speed camers database into the ipaq last month, but the latest files will not paste into the western europe folder, the paste option just greys out. How can I update?? |
Check that the card isn't write protected. If you have a separate cardreader try this instead - it's a lot faster.
Failing that eject and re-seat the card. _________________ Phil |
spile Regular Visitor
![](modules/Forums/images/avatars/83955668747591f315e811.jpg)
Posted: Thu Dec 06, 2007 9:19 am Post subject: |
First make sure hidden folders are not ticked (see other threads on this - search for rx5935)
Using Activesync check the filepath...
My Windows Mobile-based device ... Ipaq file store ... IPAQ GPS ... Western_Europe
Then drag and drop the files in there.
Posted: Thu Dec 06, 2007 9:50 pm Post subject: |
there is no SD card. i installed the files last month following the method on the threads, showing hidden files etc and it worked. only now i want to update i cannot paste the files in, it is greyed out of options pop up window. |
Posted: Fri Dec 07, 2007 11:20 am Post subject: |
Did you follow my advice above? |
Posted: Fri Dec 07, 2007 11:48 am Post subject: |
bl, yes but i accessed thro My Computer as i can't find Activesync on desktop or anywhere else, but i know it's installed!! |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Fri Dec 07, 2007 12:30 pm Post subject: |
dougttt wrote: | bl, yes but i accessed thro My Computer as i can't find Activesync on desktop or anywhere else, but i know it's installed!! | Are you using Vista, or XP?
For Vista there's a different program called Windows Mobile Device Centre.
In both cases if they are installed they should open a communications window on the PC screen.
Why not re-install it anyway ![Idea](modules/Forums/images/smiles/icon_idea.gif) _________________ Richard
Posted: Fri Dec 07, 2007 2:18 pm Post subject: |
i am using XP. I have now accessed ipaq through Activesync, but the result is the same. The paste option greys over when i try to copy files into Western Europe folder: \iPAQ File Store\iPAQ GPS\Western_Europe |
Posted: Mon Dec 10, 2007 5:20 pm Post subject: |
Still sound like a protection mechanism. Something must be write protected.
Can you copy ANY file to the folder?
Can you copy a camera file to any other location on the device?
Using the Mobile Device on your PC with the iPaq attached - right click on any of the camera files - select Properties... Although they are greyed out you can see the attributes for the file.
Just a last (slightly off-the-wall) thought. Do you have to delete the existing files before you can 'replace' them? I know this isn't usual for these sorts of devices.... _________________ Phil |
Posted: Tue Dec 11, 2007 10:57 am Post subject: |
Yes I can copy other files to the folder.
No I cannot copy a camera file to any other location on the device.
Weird? |
Posted: Tue Dec 11, 2007 12:34 pm Post subject: |
It sounds as though you are trying to copy the files from an open ZIP file.
Copy the files from the zip folder to your desktop (or My Documents) and then drag and drop them from there to your PPC. |
Posted: Mon Dec 31, 2007 12:07 pm Post subject: |
bl, bingo, thanks, we got there!!! much appreciated |
