Pocket GPS World :: View topic - TomTom One - Data logging?
neilsen
PostPosted: Wed Nov 28, 2007 11:29 pm    Post subject: TomTom One - Data logging? Reply with quote
I have a TomTom One, version 2 I think (OS :2326).
I've been searching online for ways to make it dump out GPS coordinates on intervals (for Geotagging) but all I seem to keep ending up at is Event_Logger, which seems to work only for TomTom Go.
Is anyone aware of anything that will handle this for the One?
PostPosted: Thu Nov 29, 2007 1:13 am    Post subject: Reply with quote
As the Go range and the one use basically the same software, it should work equally well (or not) on both. If you are still running v6 software, it will probably be fine. Version 7 on a Go OR a One may be less successful.
Have a look at "Tripmaster" as well, I've never used it myself, but it's well regarded. http://www.webazar.org/tomtom/plugins.php?lang=uk.
Tripmaster does work with v7, with some limitations.
vibeone
PostPosted: Thu Nov 29, 2007 3:12 pm    Post subject: Reply with quote
tripmaster is bloody brilliant.
I have it set to log every 0.001 miles, 1deg deviation, 1 second (which ever occurs first).
Even so often, the logs are small even on full logging mode.
Then download GPSBabel, which will convert it from NMEA to Google Earth KML.
(TRIPMASTER will do KML, but doesn't end files properly unless you manually stop it, so NMEA is better IMO).
Double click, and it shows your route in google earth :D
22.094 (25 Sep 24)
