Pocket GPS World :: View topic - GO720 Won't reset
GO720 Won't reset
PeteJohn
PostPosted: Wed Nov 28, 2007 6:27 pm    Post subject: GO720 Won't reset Reply with quote
Can anyone help me please. I have a TomTom Go720 and it will no longer start up. It gets as far as the picture but then will not go any further. When connected to the PC it connects ok but as soon as I click operate my Go then the programme crashes. Thanks
PostPosted: Wed Nov 28, 2007 6:39 pm    Post subject: Reply with quote
Have you actually done a RESET?
See the TomTom Reset Page for details.
PeteJohn
PostPosted: Wed Nov 28, 2007 7:19 pm    Post subject: Reply with quote
Yes I meant to have said. I performed a reset but it makes no difference
PostPosted: Thu Nov 29, 2007 12:13 am    Post subject: Reply with quote
In that case there is probably a corrupted operating system file somewhere.
Two questions:
Did you do anything (update, add, or move anything in the flash memory, or add an SD card) before this happened?
Did you make any backups before this happened?
PeteJohn
PostPosted: Thu Nov 29, 2007 4:31 pm    Post subject: Reply with quote
I did try to install the POI Capture and I think this caused the problem. Unfortunately I did not make a back up. If this is a corrupted file is there anything I can do?
PostPosted: Thu Nov 29, 2007 6:30 pm    Post subject: Reply with quote
POICapture, at this time, doesn't work correctly with V7 software.
If there is a corrupt system file, I would follow the instructions in This Post.
What you are doing is removing all the system files (those not in the Folders) and then re-installing the software. At this stage ignore the part about Formatting the Card. Just follow the paragraph that starts "Please connect ....".
But PLEASE do a Full Backup using Explorer first.
PeteJohn
PostPosted: Thu Nov 29, 2007 6:49 pm    Post subject: Reply with quote
Many thanks. I will try this and let you know tomorrow.
PeteJohn
PostPosted: Fri Nov 30, 2007 7:44 pm    Post subject: Reply with quote
Many thanks for your help everything is now working ok
