wibbly Frequent Visitor
Posted: Thu Nov 22, 2007 8:41 am Post subject: Screen updates on TT1V2 Europe |
I recently wound up using my TT without the camera database in it. Screen updates are much more frequent and thus fluid. With all the camera POIs active update are one or two a second.
Does anyone know if the slow down is a product of the sheer number of cameras or the number of POI groups, mainly? I'm just wondering if it's likely to help I use something different from the "speed zoned complete" version |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Thu Nov 22, 2007 9:46 am Post subject: |
Do you have them Enabled in the Enable/Disable Menu, as well as Warn When Near?
The Enable Function is more of a problem with the PDA variants, but is still a bit of an overhead with All-in-Ones.
It isn't necessary to Enable them unless you want to see them on Browse Map. _________________ Richard
Posted: Thu Nov 22, 2007 10:13 am Post subject: |
Yup. The whole lot enabled, and all with "warn when near" active. I couldn't see the point of enabling only some of them this way. Is there? |
Andy_P Pocket GPS Moderator
Posted: Thu Nov 22, 2007 10:30 am Post subject: |
Yes there is...
"Enabling" them shows them on the "Browse map" view AND on the normal Navigation view as soon as the come "over the horizon".
If you just have the "Warn when near" set up, they won't appear on "Browse map", but they will still appear on the normal Navigation view, popping on at whatever distance you have set for the warning.
Much less load on the CPU that way. |
Posted: Thu Nov 22, 2007 10:51 am Post subject: |
Andy_P2002 wrote: | popping on at whatever distance you have set for the warning. |
Really? Will try that! Thanks very much. I didn't really that would be the behaviour :-) |
tanda Lifetime Member
Joined: Aug 21, 2005 Posts: 617 Location: Gloucester UK
Posted: Thu Nov 22, 2007 4:30 pm Post subject: |
Wouldn't a faster read SD card help? _________________ Audi A3 Sline sat nav |
Posted: Thu Nov 22, 2007 4:46 pm Post subject: |
tanda wrote: | Wouldn't a faster read SD card help? |
Nope.
1. I'd hope this kind of data is cached in RAM anyway
2. It's already a Sandisk Extreme III ;-) |
