Pocket GPS World :: View topic - Screen updates on TT1V2 Europe
wibbly
PostPosted: Thu Nov 22, 2007 8:41 am    Post subject: Screen updates on TT1V2 Europe Reply with quote
I recently wound up using my TT without the camera database in it. Screen updates are much more frequent and thus fluid. With all the camera POIs active update are one or two a second.
Does anyone know if the slow down is a product of the sheer number of cameras or the number of POI groups, mainly? I'm just wondering if it's likely to help I use something different from the "speed zoned complete" version
Oldboy
PostPosted: Thu Nov 22, 2007 9:46 am    Post subject: Reply with quote
Do you have them Enabled in the Enable/Disable Menu, as well as Warn When Near?
The Enable Function is more of a problem with the PDA variants, but is still a bit of an overhead with All-in-Ones.
It isn't necessary to Enable them unless you want to see them on Browse Map.
wibbly
PostPosted: Thu Nov 22, 2007 10:13 am    Post subject: Reply with quote
Yup. The whole lot enabled, and all with "warn when near" active. I couldn't see the point of enabling only some of them this way. Is there?
PostPosted: Thu Nov 22, 2007 10:30 am    Post subject: Reply with quote
Yes there is...
"Enabling" them shows them on the "Browse map" view AND on the normal Navigation view as soon as the come "over the horizon".
If you just have the "Warn when near" set up, they won't appear on "Browse map", but they will still appear on the normal Navigation view, popping on at whatever distance you have set for the warning.
Much less load on the CPU that way.
wibbly
PostPosted: Thu Nov 22, 2007 10:51 am    Post subject: Reply with quote
Really? Will try that! Thanks very much. I didn't really that would be the behaviour :-)
tanda
PostPosted: Thu Nov 22, 2007 4:30 pm    Post subject: Reply with quote
Wouldn't a faster read SD card help?
Audi A3 Sline sat nav
wibbly
PostPosted: Thu Nov 22, 2007 4:46 pm    Post subject: Reply with quote
Nope.
1. I'd hope this kind of data is cached in RAM anyway
2. It's already a Sandisk Extreme III ;-)
22.071 (03 Jul 24)
