Pocket GPS World :: View topic - Soft Reset V Hard Reset
mikeshe
PostPosted: Sat Apr 10, 2004 11:13 pm    Post subject: Soft Reset V Hard Reset Reply with quote
Firstly, what is the difference between a hard and soft reset?
Secondly, how do you do a hard reset?
Thanks,
Mike
PostPosted: Sat Apr 10, 2004 11:25 pm    Post subject: Reply with quote
A soft reset is the same as if you would restart your desktop or laptop computer. A hard reset is equivalent to inserting the recovery CD and copletely reinstalling the operating system. After a hard reset all your nrew programs and personal files are gone.
Doing a hard reset is different per PocketPC. Here's a good introduction: http://www.pocketpcthoughts.com/forums/viewtopic.php?p=225725
Arimus
PostPosted: Sat Apr 10, 2004 11:27 pm    Post subject: Reply with quote
Soft Reset: This just resets the device without clearing data and programs installed. This should be the first thing you try if your device has locked up and is no longer responding as it will terminate all programs but preserve your data (unsaved data will be lost) and user settings/installed programmes etc.
Hard Reset: This will clear all data/settings/user installed programs (on some (all?) pocket pc devices the address book/other organiser data may survive) - effectively returning the device to its 'out of the box' state.
How? Without knowing your device model its hard to say what you have to do to initiate either type of reset.
--<br>
Users a like a virus, each one causing a thousand tiny crises until the host finally dies.
51:35:00N 03:13:36W
mikeshe
PostPosted: Sun Apr 11, 2004 11:25 am    Post subject: Reply with quote
Many thanks for your help.
My PPC is an Ipaq 3970, which I purchased second hand. There is quite a bit of stuff on it that I wouldn't use that the previous owner put on and I would like to start off with a new "out the box" system.
I also have TTN2, do I install all of this onto my storage card or do I install some of it to main memeory and the maps to storage? Can you select where to install?
Many thanks,
Mike
Arimus
PostPosted: Sun Apr 11, 2004 12:50 pm    Post subject: Reply with quote
From the getting started guide:
Soft Reset:
" My Compaq iPAQ Pocket PC is not responding or an application hangs
Perform a soft reset of your Compaq iPAQ Pocket PC:
1 Insert the stylus into the unit reset switch at the bottom of your Compaq iPAQ Pocket PC
2 Press the switch for 1 second"
"Perform a hard reset of your Compaq
iPAQ Pocket PC
CAUTION: Because most of
the applications and data you
install on your Compaq iPAQ
Pocket PC are held in memory,
you will need to reinstall them if
you perform a hard reset.
1 Press and hold the two
outside application buttons
2 Insert the stylus into the unit
3 Press the switch for
5 seconds
4 To reactivate your Compaq
iPAQ Pocket PC, insert the
switch and press the switch
for 1 second or connect your
Compaq iPAQ Pocket PC to
the AC Adapter"
PostPosted: Sun Apr 11, 2004 2:42 pm    Post subject: Reply with quote
You can select where to install. I recommend the following
Application: Storage card
GPS driver: main memory (it won't install to storage card anyhow)
maps: storage card
Make sure you backup the "TomTom Navigator.axs" file before you do the hard reset - it contains your Activation Code..
mikeshe
PostPosted: Sun Apr 11, 2004 3:27 pm    Post subject: Reply with quote
Many thanks to everyone for the help you have given me, it's nice to know the correct waysinsteading of charging in blind and this is all due to you good people. Thumbs Up
Mike
22.064 (26 Jun 24)
