Pocket GPS World :: View topic - HELP - Sapphire 2000/Autoroute 2002/Ipaq 3760
tinapatra
PostPosted: Sat Apr 10, 2004 6:53 pm    Post subject: HELP - Sapphire 2000/Autoroute 2002/Ipaq 3760 Reply with quote
Hi there
I am having trouble with getting the Ipaq to receive a signal from the GPS receiver. I have all the correct cables/installed Pocket streets OK and the receiver works fine with my laptop. Sad
Any ideas would be most welcome.
Looking forward to hearing from you.
All the best
tinapatra
lbendlin
PostPosted: Sat Apr 10, 2004 6:54 pm    Post subject: Reply with quote
The receiver works fine with your laptop? On the serial or the USB port?
Lutz
TomTom/TeleAtlas NAVTEQ
tinapatra
PostPosted: Sat Apr 10, 2004 6:59 pm    Post subject: Reply with quote
USB
lbendlin
PostPosted: Sat Apr 10, 2004 7:11 pm    Post subject: Reply with quote
There's your problem. The iPAQ needs the serial version of the RGM2000
Lutz
PostPosted: Sat Apr 10, 2004 7:12 pm    Post subject: Reply with quote
I presume you have the correct iPAQ cable for the Sapphire and you're not just trying to plug the Sapphire into a USB socket like on the cradle ?
If you have the iPAQ lead connected to the Sapphire then you won't need any drivers installed, it will use COM1, NMEA 4800.
tinapatra
PostPosted: Sun Apr 11, 2004 10:48 am    Post subject: HELP - Sapphire 2000/Autoroute 2002/Ipaq 3760 Reply with quote
Sorry I posted this to your e-mail before I read your footnote so I have copied it here as requested.
Best regards
tinapatra
Dear Dave
Yes I have the correct converter cable for my Ipaq. It runs off the cigarette lighter in my car with the ignition on and powers both the Ipaq and the GPS receiver. Nothing happens. How can I set my Ipaq to COM1 as you suggest.
I look forward to hearing from you.
Best regards
lbendlin
PostPosted: Sun Apr 11, 2004 2:39 pm    Post subject: Reply with quote
What GPS program are you using on the iPAQ?
Lutz
tinapatra
PostPosted: Sun Apr 11, 2004 3:26 pm    Post subject: Reply with quote
Pocket streets from MS Autoroute 2002
lbendlin
PostPosted: Sun Apr 11, 2004 3:59 pm    Post subject: Reply with quote
Tools...Gps...Configure GPS receiver...COM1:
Then
Tools...GPS...Track Position
Lutz
tinapatra
PostPosted: Sun Apr 11, 2004 4:18 pm    Post subject: Reply with quote
I have it working fine on my laptop which is done the way you say. However I cannot configure it on my Ipaq PDA. Any ideas?
lbendlin
PostPosted: Sun Apr 11, 2004 4:22 pm    Post subject: Reply with quote
The instructions were for the PDA, not for the Laptop.
Lutz
tinapatra
PostPosted: Sun Apr 11, 2004 4:39 pm    Post subject: Reply with quote
Sorry I must be thick but I can't find Tools on the PDA. In Pocket Streets Tools there is no GPS to configure.
Able to display maps on PDA.
lbendlin
PostPosted: Sun Apr 11, 2004 5:12 pm    Post subject: Reply with quote
1. launch Pocket Streets
2. Select map (the one the you have exported from the LapTop to the PDA)
3. The Tools menu is at the left bottom side.
4. follow instructions
Lutz
tinapatra
PostPosted: Sun Apr 11, 2004 5:28 pm    Post subject: Reply with quote
Done that but there is no GPS in the Tools.
lbendlin
PostPosted: Sun Apr 11, 2004 5:33 pm    Post subject: Reply with quote
You must have a very old version of Pocket Streets then. I am using the one from the Microsoft site (Pocket Streets 2002, version 11.00) and it does have this menu item.
Lutz
22.101 (03 Oct 24)
