Pocket GPS World :: View topic - tom tom one v3 remove tips
Goto page 1, 2, 3  Next
yebaws
PostPosted: Sat Nov 17, 2007 2:58 pm    Post subject: tom tom one v3 remove tips Reply with quote
I get random "useful" tips coming up when I do things on my tt. Anybody know how to stop them?
46jimbo
PostPosted: Sat Nov 17, 2007 3:01 pm    Post subject: Reply with quote
Isn't it possible to turn this feature off in the 'Preferences' section?
yebaws
PostPosted: Sat Nov 17, 2007 3:05 pm    Post subject: Reply with quote
I can't find it anywhere...
sixhundred
PostPosted: Sat Nov 17, 2007 3:32 pm    Post subject: Reply with quote
Preferences> Safety Preferences. Un tick them all.
Even with all this off I still get the occasional "don't forget to connect to a PC" message.
PostPosted: Sat Nov 17, 2007 4:19 pm    Post subject: Reply with quote
sixhundred wrote:
Preferences Safety Preferences. Un tick them all.
Have you tried the last page of Change Preferences. There is an Option to Hide Tips.
TT Via 135 App 12.075: Europe Map v1140
yebaws
PostPosted: Sat Nov 17, 2007 5:15 pm    Post subject: Reply with quote
Not on my tt (v3)
PostPosted: Sat Nov 17, 2007 5:33 pm    Post subject: Reply with quote
If you have a One third Edition there is no "Hide Tips" all you can do is keep answering NO to the Tips and after a while it should ask you if you want to stop having tips displayed at all, IF it does ask this question make sure you answer it correctly to stop it from further stupid messages, there are no other selections in the menu screens that I know of to turn this off!! - Mike
yebaws
PostPosted: Sat Nov 17, 2007 5:35 pm    Post subject: Reply with quote
all unticked already...
yebaws
PostPosted: Sat Nov 17, 2007 5:36 pm    Post subject: Reply with quote
umm... don't get the option to say "no" either
PostPosted: Sat Nov 17, 2007 5:41 pm    Post subject: Reply with quote
But what device is it? - there is loads on confusion with respect to numbers and versions etc. Look at the box and does it say "One Third Edition" if you don't have the box to hand does the device have an SD card slot on the base plate or not? - Mike
yebaws
PostPosted: Sat Nov 17, 2007 7:06 pm    Post subject: Reply with quote
Deffinately tomtom one version 3 (W europe). Only had it a couple of weeks and the box is sitting here...
No sd card, internal 1gb memory
yebaws
PostPosted: Sat Dec 01, 2007 1:44 pm    Post subject: Reply with quote
bump...
PostPosted: Sat Dec 01, 2007 2:54 pm    Post subject: Reply with quote
Throw a custom menu on the device and include the syntax
TASK_SWITCH_TIPS
In one line, use this to disable the tips then remove the custom menu to get the original menu back, unless you want to costruct your own menu to gain access to Itinerary Planning and the proper POI functions - Mike
yebaws
PostPosted: Sat Dec 01, 2007 3:39 pm    Post subject: Reply with quote
TASK_SWITCH_TIPS
Hi Mike,
Thanks, this looks like it may do the job. I read your excellent review of TT1 V3 and was planning to follow your instructions to make a custom menu to get itinerary and poi features back. If I follow those instructions and also add the line:
MENUITEM|TASK_SWITCH_TIPS|
Will this do the job?
Thanks,
Justin
PostPosted: Sat Dec 01, 2007 5:44 pm    Post subject: Reply with quote
Yes that syntax will work and allow you to knock off the tips, if you want any help with the menu text or configuration let us know as we can post up a suggested text to load to the device.
The One Third Edition can even display and use text documents with the correct command line in the menu should you need this - Mike
Page 1 of 3
23.015 (29 Jan 25)
