Pocket GPS World :: View topic - TomTom 500 Master Reset
Goto page Previous  1, 2
Colonelgrey
PostPosted: Fri Nov 16, 2007 11:19 pm    Post subject: TomTom 500 Master Reset Reply with quote
Thanx 4 your help all, but when you master reset, all of the POI's, voices etc remain on board, hence the question. PS: Where is Lud? Laughing
Pufin
PostPosted: Sat Nov 17, 2007 12:40 am    Post subject: Reply with quote
Why don't go into each folder via your PC explorer and delete the relevant files?
Want to get lost, forget your Tomtom next time you go out?
Or should that be Take your TomTom with you!
Two TomTom 500's
App 7.161 GPS v1.21 Boot 4.8600 Map Western_Europe_1GB v710.1561
Installed on 2gig sd cards.
PostPosted: Sat Nov 17, 2007 1:36 am    Post subject: Re: TomTom 500 Master Reset Reply with quote
Anywhere south of Yorkshire!
PostPosted: Sat Nov 17, 2007 7:32 pm    Post subject: Reply with quote
I thought "Reset to Factory Settings" (as opposed to pressing the reset button) should remove everything YOU'VE added, but looking at the manual for my Go it actually says
All your settings, including Favourites, your Home location, warnings for
POIs and any Itineraries you have created, as well as recent destinations
and recent calls and callers, will be deleted.
so maybe it doesn't remove the content, only the setup files which use the content.
In that case you would have to remove them from the individual folders as Pufin says.
.ov2 and .bmp files from the Map folder for POIs
dataxx.chk and .vif files from the voices folder (leaving low numbered ones like 04 and 05 whch are the standard UK voices)
anything in the itn, contacts and schemes folders
Should cover most things...
Page 2 of 2
22.063 (19 Jun 24)
