Robs321 Occasional Visitor
Posted: Tue Nov 13, 2007 5:10 pm Post subject: Tomtom 1 identity crisis! |
Ive just replaced the battery in my tomtom one V1 and after rebooting it, it now thinks its a tomtom rider, it all works fine apart from I have no sound as it wants to connect to a blue tooth device for this to work!
any help gratefully recieved!
cheers
Robs |
Andy_P Pocket GPS Moderator
Posted: Tue Nov 13, 2007 5:34 pm Post subject: |
When you say it thinks it's a Rider, is it actually saying that somewhere? Or is there just no sound?
If #2, I'd say you have to be taking it all apart again.... |
Posted: Tue Nov 13, 2007 5:42 pm Post subject: |
its booting up and saying its a rider! its looking for a rider bluetooth ear piece! I have no idea why!
cheers
Robs |
Posted: Tue Nov 13, 2007 5:45 pm Post subject: |
Bizarre!! That's a new one on me! |
Posted: Tue Nov 13, 2007 7:25 pm Post subject: |
Try holding the reset for 30 seconds then boot it up, also can you tell us the version of software installed to the device? - have you changed the device software recently - Mike |
Posted: Tue Nov 13, 2007 7:49 pm Post subject: |
tried the 30sec trick and no difference! i recently put in a new official western europeon map(2 gig) and its been fine, it was only after replacing the battery that this identity crisis happened ! firmware is App 6.560 (7914/061211)OS:1713
cheers
Robs |
Posted: Tue Nov 13, 2007 7:52 pm Post subject: |
Do you have a back up and spare SD card? - if so load that with the old software/ map and see if boots correctly - Mike |
Posted: Tue Nov 13, 2007 11:42 pm Post subject: |
mikealder wrote: | Do you have a back up and spare SD card? - if so load that with the old software/ map and see if boots correctly - Mike |
yup and it doesnt! looks like Ill have to get a new one, will i be able to use the new sd card i got in a new tomtom one?
cheers
Robs |
Posted: Wed Nov 14, 2007 7:22 am Post subject: |
Yes you can use the card in any of the TomTom products as long as the device has an SD card slot, avoid the latest TomTom One (Third Edition) because that relies upon internal flash memory with no expansion slot. You will also have to get TomTom to activate your recent map purchase for the new device, be prepared to send them a copy of your purchase receipt for the new unit - Mike |
volte Occasional Visitor
Posted: Sun May 18, 2008 11:44 pm Post subject: Re: Tomtom 1 identity crisis! |
Robs321 wrote: | Ive just replaced the battery in my tomtom one V1 and after rebooting it, it now thinks its a tomtom rider, it all works fine apart from I have no sound as it wants to connect to a blue tooth device for this to work!
cheers
Robs |
Wow, I know this thread is 6 months old, but I've got the same problem!!!
It has happened a few times to my original tomtom one over the last year, but I could never find anyone else reporting the same problem, and each time I've managed to get it back to normal eventually. It always happens after I have dropped the unit. It happened again tonight, but luckily it was in the case when I dropped it coming into the house.
Now it's asking to connect to a bluetooth headset, and it's allowing me to get to the screen to dial phone numbers etc! It's just let me download my phone numbers onto the tomtom one! Now this is weird.
Like I said it only happens when it gets a knock - I used to mount it on the big plastic speedo on my mini, but it was always falling off - most times it would then think it was a Rider, and I would have to reset it over and over again, sometimes holding the reset button down for several minutes until it would work.
Anyone else experienced this?! Anyone got a theory why it would act like this? I need to use my Tomtom tomorrow so will probably spend half the night resetting it. |
Posted: Sun May 18, 2008 11:52 pm Post subject: |
What a brilliant post!
I must admit I've never heard of a One turning into a Rider after a bit of a bump before, but I'm prepared to believe anything about TomTom's these days! |
Posted: Mon May 19, 2008 6:44 am Post subject: |
Do they have the same internals? Wonder if there's a switch to change "mode"? |
bmuskett Lifetime Member
Joined: May 12, 2006 Posts: 710 Location: Stockport, Cheshire
Posted: Mon May 19, 2008 7:30 am Post subject: |
Interesting. I replaced the battery on my TomTom One v1 this week and it seems to be fine. When it boots up it welcomes me to my TomTom ONE. |
