Pocket GPS World :: View topic - speed limit correction
highlander317
PostPosted: Fri Nov 09, 2007 10:13 pm    Post subject: speed limit correction Reply with quote
How do i make a correction to an existing speed limit? tried using the google map page but couldnt do anything
PaulB2005
PostPosted: Sat Nov 10, 2007 12:02 am    Post subject: Reply with quote
Speed Limit of a road or the trigger speed for a camera?
highlander317
PostPosted: Sat Nov 10, 2007 10:08 am    Post subject: Reply with quote
speed limit on a road. I used the speed zoned camera poi on my garmin 510d and quite a few local speed limits are wrong, was looking to submit the correct ones.
PaulB2005
PostPosted: Sat Nov 10, 2007 10:31 am    Post subject: Reply with quote
Only the trigger speeds for the cameras can be changed here. The Garmin units don't contain any data on Road Speed Limits - only the Speed Camera Database contains any speed limit data.
Do you mean you have a road that has a posted limit of 40 mph but the cameras are showing a limit of 50 or 30 mph, for example? If so, you can make the submission in the yellow section on the Camera page - CLICK HERE Fill in the relevant detail for the camera and submit it as a Change Exisiting Camera.
highlander317
PostPosted: Sat Nov 10, 2007 10:33 am    Post subject: Reply with quote
No i travel along a road with no cameras, speed limit is 40 mph yet the speed zoned bit tells me it 30 mph another local road says 50mph when its 60 mph
PostPosted: Sat Nov 10, 2007 10:38 am    Post subject: Reply with quote
highlander317 - what device are you using?
It sounds as if you have a TomTom with a V6xx Map. If it is it's a known problem.
highlander317
PostPosted: Sat Nov 10, 2007 10:39 am    Post subject: Reply with quote
no its a street pilot C510 d
PostPosted: Sat Nov 10, 2007 10:57 am    Post subject: Reply with quote
Are you saying that it's the Map Data that's giving the incorrect warning?
If so there's not a lot that can be done without an upgraded Map. Sad
highlander317
PostPosted: Sat Nov 10, 2007 11:00 am    Post subject: Reply with quote
i use the zoned speed camera poi's so i presume its them thats wrong nothing to do with my unit, or the maps. Who ever submitted these speed limits for these roads got it wrong all i wanna do is correct them
PostPosted: Sat Nov 10, 2007 11:03 am    Post subject: Reply with quote
Can you tell us where these errors actually are to check them out, and what sort of error are you getting? i.e. what speed are you travelling at when the waring occurs? - Mike
highlander317
PostPosted: Sat Nov 10, 2007 11:30 am    Post subject: Reply with quote
Centre Latitude: 51.822092078680725 Longitude: 1.1347675323486328
Thats using the google map on the pocketgps site.
When i was trying to get it changed last night the speed symbols were showing but not now. Im 100% sure its 60 mph and not the 50 mph it says
PaulB2005
PostPosted: Sat Nov 10, 2007 12:02 pm    Post subject: Reply with quote
highlander317 - I have to make this clear. The speed zoned database contains information on CAMERA LOCATIONS and their trigger speeds and Camera Locations and their trigger speeds ONLY. It does NOT contain any information on general speed limits.
I have an i3 and it gives me alerts like Speed Alert:30 Mph Ahead occasionally but that information is nothing to do with the PGPSW database. It some internal information from the map and can't be changed.
Does the alert say something like GATSO:12345@50 ??? If so, what is the number where i have put 12345?
Is it the A133? There is a Mobile camera on that road close to the co-ords you gave...
PostPosted: Sat Nov 10, 2007 12:03 pm    Post subject: Reply with quote
That's the bit that threw me. Embarassed
PostPosted: Sat Nov 10, 2007 12:08 pm    Post subject: Reply with quote
From the coordinates given it would appear to be pMobile 37889@50, from the comments above it looks like the speed limit is 60 but the camera is incorrectly showing as 50 - if this is the case please submit the change via the download page use the "Expand for single camera Input" It is in yellow on the page, this will open up to reveal boxes to fill in - Mike
highlander317
PostPosted: Sat Nov 10, 2007 4:43 pm    Post subject: Reply with quote
Just changed the 2 sites that were not right. Thanks for the help guys
23.092 (10 Sep 25)
