Pocket GPS World :: View topic - New way to do custom POI warnings in TomTom 5 & 6
Goto page Previous  1, 2, 3 ... 30, 31, 32, 33, 34, 35  Next
iql
PostPosted: Sun Sep 23, 2007 10:03 am    Post subject: Reply with quote
Gave ogg files a go with my TomTom One v2 and it still asks for a alert sound ?
TomTom One V2, App 7.120, Maps v660.1219
Can they be used with this unit ?
Alistair
TomTom One V2 / Start 25
Garmin i3 (old maps)
QUEMCUNQUE MISERUM VIDERIS HOMINEM SCIAS
[Whomsoever you see in distress, recognize in him a fellow man].
PostPosted: Sun Sep 23, 2007 10:13 am    Post subject: Reply with quote
When it asks you "is this the correct sound" and presents a list of available beeps/ bells, cows etc simply answer "Yes" without selecting anything at all and the unit will pick and use the ogg file.
Do not press "No" otherwise the device will lock up, the only way around this (once locked up) is to press the reset button.
When you have the warnings set-up use Advanced planning AtoB to set up a route that passes a camera, then use Route Demo to try it and make sure the warnings are indeed working, there are some detailed instructions on this see #5 on This Page - Mike
Jackaws
PostPosted: Tue Nov 06, 2007 8:38 am    Post subject: Reply with quote
Hi all,
Does anybody know if the .ogg files will work on the new TT 520?
Cheers.
PostPosted: Tue Nov 06, 2007 8:41 am    Post subject: Reply with quote
They work fine on the x20 devices, just bear in mind when it asks the question about "is this the correct sound" you have to answer Yes (even though it plays no sound) - if you answer No the deice will lock up displaying a message about missing pictures. A reset will cure this problem though - Mike
Jackaws
PostPosted: Tue Nov 06, 2007 8:59 am    Post subject: Reply with quote
Thanks for the prompt reply. Much appreciated.
Am I right in thinking that I can just download the relevant 'voice alert collection' and unzip it straight into my UK maps folder next to the ov2 and bmp file for the pocketgps speed cameras POI's then reset each POI warning as you've described above?
PostPosted: Tue Nov 06, 2007 9:06 am    Post subject: Reply with quote
If you do what you have described in the previous post then it will all work fine, so I guess you understand whats required, if you get stuck just ask you know where the forum is.
One bit I will add is once you have configured all the POI use
AtoB (advanced planning) and set a
Departure point:
FY43NN House 95
Destination:
PR41AX House 33
Next set route demo going to play back your warnings, the route offered above will give a number of different camera warnings as the device leaves Blackpool on a virtual drive (cheaper than burning fuel to see if it works) - Mike
Jackaws
PostPosted: Tue Nov 06, 2007 9:08 am    Post subject: Reply with quote
Cheers Mike, you're a fountain of knowledge.
Just about to try it.
Thanks again,
Andy Razz
Jackaws
PostPosted: Tue Nov 06, 2007 9:12 am    Post subject: Reply with quote
Hi Mike,
Hit a glitch! Each time I update the individual POI's to include the .ogg files it plays a confirmation sample after I've done so. Each one says 'gatso 30' not 'gatso 40, gatso 60, etc'.
Am I doing something wrong? Shocked
PostPosted: Tue Nov 06, 2007 9:14 am    Post subject: Reply with quote
Which Speed Camera database and ogg file sets have you installed to the device? - Mike
Jackaws
PostPosted: Tue Nov 06, 2007 9:23 am    Post subject: Reply with quote
Speed zoned version with 'bing bong chime'. I think I know what it is though. as I'm using the TT to update the POI alerts it's picking up a mobile (30) that I've set in an adjacent street to where I live. Sorted. I said gatso in my previous post. Should have been mobile. Sorry.
Another issue, there doesn't appear to be .ogg files for the pmobile cameras. Is this correct? Is there a work around for this or do you have to chose one of the standard TT sounds?
Oldboy
PostPosted: Tue Nov 06, 2007 9:41 am    Post subject: Reply with quote
On the OGG File Page, near the bottom, there are a couple.
One with a chime, and one without the chime.
TT Via 135 App 12.075: Europe Map v1135
Jackaws
PostPosted: Tue Nov 06, 2007 9:46 am    Post subject: Reply with quote
Thanks. I should have looked further down. Embarassed
Jackaws
PostPosted: Tue Nov 06, 2007 10:06 am    Post subject: Reply with quote
I have installed the .ogg files successfully and run a demo around various safety camera sites (using TT Home on my PC) and it works fine. I've disconnected the device and run the same demo. The voices alerts are very slow. The young lady's voice now sould like a drunk man!
Can you help?
PostPosted: Tue Nov 06, 2007 12:14 pm    Post subject: Reply with quote
Interesting....
First thing to try is a reset.
Other than that, the only thing I can think of so far is if you've somehow used a version for TomTom Navigator on a PDA that uses a lower sampling frequency. But you say it sounds OK when using the "virtual" machine in Home?
I'll try a few experiments...
Jackaws
PostPosted: Tue Nov 06, 2007 5:23 pm    Post subject: Reply with quote
Thanks for the suggestion. Tried this, seems to have done the trick.
Thanks again.
Andy Very Happy
Page 31 of 35
22.094 (25 Sep 24)
