Adyc Occasional Visitor
Posted: Sun Nov 04, 2007 1:45 pm Post subject: GO 710 ACTIVATION code |
I have a go 710 and this morning downloaded updates for it. I went through the product and device code process but when I come to the activation code it says it is not valid. I have checked and rechecked I have typed in ok. Any help much appreciated. |
brian3315 Occasional Visitor
Joined: Feb 18, 2005 Posts: 37 Location: South Cheshire
Posted: Sun Nov 04, 2007 2:08 pm Post subject: |
If you used TT Home you do not need codes. Suggest if you did not use Home go to a previously backed up version and download all updates through Home. Hope this helps. |
Posted: Sun Nov 04, 2007 3:40 pm Post subject: |
Yes i used home. Was a new version of software though. |
Posted: Sun Nov 04, 2007 3:55 pm Post subject: |
On initial turn on I get unable to store settings:file access error.
This is after trying to restore backup as well. |
vibeone Lifetime Member
Posted: Sun Nov 04, 2007 5:06 pm Post subject: |
Adyc wrote: | On initial turn on I get unable to store settings:file access error.
sd card lock is on?
theres a little switch on the sd card itself, a write lock. it needs to be disabled. |
Posted: Sun Nov 04, 2007 5:46 pm Post subject: V7.16 |
I seem to br running v 7.16 which gives the error. When I try to restore back up it doesn't work. Any ideas? |
HummerUK Frequent Visitor
![](modules/Forums/images/avatars/543239219476af1a6ee8cb.jpg)
Joined: Apr 21, 2007 Posts: 332 Location: East Sussex
Posted: Mon Nov 05, 2007 3:48 pm Post subject: |
I am confued to why they still pack the units with a card with an activation code on it that does not work.
Even the TTHome V2 takes you to the place to enter the code also that does not work.
HummerUK |
