Pocket GPS World :: View topic - GO 710 ACTIVATION code
Adyc
PostPosted: Sun Nov 04, 2007 1:45 pm    Post subject: GO 710 ACTIVATION code Reply with quote
I have a go 710 and this morning downloaded updates for it. I went through the product and device code process but when I come to the activation code it says it is not valid. I have checked and rechecked I have typed in ok. Any help much appreciated.
brian3315
PostPosted: Sun Nov 04, 2007 2:08 pm    Post subject: Reply with quote
If you used TT Home you do not need codes. Suggest if you did not use Home go to a previously backed up version and download all updates through Home. Hope this helps.
Adyc
PostPosted: Sun Nov 04, 2007 3:40 pm    Post subject: Reply with quote
Yes i used home. Was a new version of software though.
Adyc
PostPosted: Sun Nov 04, 2007 3:55 pm    Post subject: Reply with quote
On initial turn on I get unable to store settings:file access error.
This is after trying to restore backup as well.
vibeone
PostPosted: Sun Nov 04, 2007 5:06 pm    Post subject: Reply with quote
sd card lock is on?
theres a little switch on the sd card itself, a write lock. it needs to be disabled.
Adyc
PostPosted: Sun Nov 04, 2007 5:46 pm    Post subject: V7.16 Reply with quote
I seem to br running v 7.16 which gives the error. When I try to restore back up it doesn't work. Any ideas?
HummerUK
PostPosted: Mon Nov 05, 2007 3:48 pm    Post subject: Reply with quote
I am confued to why they still pack the units with a card with an activation code on it that does not work.
Even the TTHome V2 takes you to the place to enter the code also that does not work.
HummerUK
22.093 (18 Sep 24)
