Pocket GPS World :: View topic - GO 710 ACTIVATION code
Adyc
PostPosted: Sun Nov 04, 2007 1:45 pm    Post subject: GO 710 ACTIVATION code Reply with quote
I have a go 710 and this morning downloaded updates for it. I went through the product and device code process but when I come to the activation code it says it is not valid. I have checked and rechecked I have typed in ok. Any help much appreciated.
brian3315
PostPosted: Sun Nov 04, 2007 2:08 pm    Post subject: Reply with quote
If you used TT Home you do not need codes. Suggest if you did not use Home go to a previously backed up version and download all updates through Home. Hope this helps.
Adyc
PostPosted: Sun Nov 04, 2007 3:40 pm    Post subject: Reply with quote
Yes i used home. Was a new version of software though.
Adyc
PostPosted: Sun Nov 04, 2007 3:55 pm    Post subject: Reply with quote
On initial turn on I get unable to store settings:file access error.
This is after trying to restore backup as well.
vibeone
PostPosted: Sun Nov 04, 2007 5:06 pm    Post subject: Reply with quote
sd card lock is on?
theres a little switch on the sd card itself, a write lock. it needs to be disabled.
Adyc
PostPosted: Sun Nov 04, 2007 5:46 pm    Post subject: V7.16 Reply with quote
I seem to br running v 7.16 which gives the error. When I try to restore back up it doesn't work. Any ideas?
HummerUK
PostPosted: Mon Nov 05, 2007 3:48 pm    Post subject: Reply with quote
I am confued to why they still pack the units with a card with an activation code on it that does not work.
Even the TTHome V2 takes you to the place to enter the code also that does not work.
HummerUK
