Pocket GPS World :: View topic - Map of Western Europe v7.10
Goto page Previous  1, 2, 3, 4, 5, 6 ... 10, 11, 12  Next
NukeThemAll
PostPosted: Fri Nov 02, 2007 10:01 pm    Post subject: Reply with quote
The W&CE map is supposedly more detailed than the WE mapset (I recall a thread discussing how the previous version of the WE map had been 'simplified' to fit on a 1Gb card). Yes, if you go to TomTom's website and it thinks you have a TT1 (and quite a few other devices) it won't show the W&CE map as a viable choice. Pretending your device is a 920 will show the choice.
Another thread discussed which map is compatible with which device and as I recall this W&CE map would certainly work on my TT1.
Yes, right, problem is, if the W&CE map can only be downloaded **and installed** via TTHome, which knows I have a TT1.....er, how do I acquire said map?
TT GO app on Android Phone
madou
PostPosted: Fri Nov 02, 2007 10:35 pm    Post subject: Reply with quote
Good point ! Home does not seem to check for the amount of memory you have installed, but rather the amount of memory that came with the device from the factory
I have installed a 2GB SD in addition to the on board 720 memory. Is this just additive, or is there still some switch between inbuilt and SD ?
Scainer
PostPosted: Sat Nov 03, 2007 1:08 am    Post subject: Reply with quote
With an SD card installed, connect to HOME and it'll give you the option of which memory location to use.
Select the SD card and then install you chosen map.
Once you load up the tomtom, all the maps are shown regardless of location.
Jonny_doe
PostPosted: Sat Nov 03, 2007 7:52 am    Post subject: Reply with quote
I've just bought this map , and installed it , and i'm dissapointed to see that this map still hasn't had the road changes in the center of Bristol (due to a new shopping center ) , but with my friends Rider with map 675 (navteq) it's all been changed .... Looks like i've bought the wrong map Sad
TomTom 910
App 7.160
Map 'Western_and_Central_Europe' v710.1561
iyad
PostPosted: Sat Nov 03, 2007 9:17 am    Post subject: Reply with quote
Just noticed something, I have had my 720 much more than the 30 days and still being offered by Home to upgrade for free, not sure why?
Still having the same problem as Scainer that after installing it on 720 it will not run and will only get Canary Islands map only.
marshall
PostPosted: Sat Nov 03, 2007 3:30 pm    Post subject: Reply with quote
Hi all
For what its worth i used my latest map option and bingo the second time i tried it downloaded and installed to my 520
can't say I have seen any difference but i suppose it has some differences????
marshall
marshall TomTom Go 520 , Western Europe v805.1801 map. app 8.2204- v7KATE 4gb sd card + other cards
duckie008
PostPosted: Sat Nov 03, 2007 3:40 pm    Post subject: Reply with quote
You need to go into 'Manage Maps' and change to Europe.
iyad
PostPosted: Sat Nov 03, 2007 4:37 pm    Post subject: Reply with quote
Duckie, I did that the only map was showing is Canary Islands eventhough the Western and Central Europe maps have been downloaded and installed
PostPosted: Sat Nov 03, 2007 4:51 pm    Post subject: Reply with quote
Have a look at the map folder using Windows Explorer and see if there is a file with the extension of .dct in the folder, if it is missing your map needs activation, for this you will need to contact TomTom support (0845 161 0009) - Mike
duckie008
PostPosted: Sat Nov 03, 2007 5:29 pm    Post subject: Reply with quote
You do mean Western Europe maps, not Central Europe?
Well, after mine downloaded and installed, i could only see the Canary Islands too. But when i went into 'change preferences', 'manage maps', i could see both Canary and Europe maps.So i chose Europe and it worked fine. Did you delete the old map before installing the new one?
rockie67
PostPosted: Sat Nov 03, 2007 5:44 pm    Post subject: Reply with quote
I bought a tomtom 910 at the end of october.It has version 6.6 maps on it.Does this mean i will have to purchase v7.10 maps.If so is there any differance.Should i just stick with the maps i have.Does anybody have any idea why i cant see the speed cameras on the maps.Could it be something to do with not have the latest maps installed.
duckie008
PostPosted: Sat Nov 03, 2007 5:55 pm    Post subject: Reply with quote
If you bought your maps at the end of Oct then you should be under the new map guarantee. Go into Home, plug in device, and click on File, map guarantee. It will tell you whether you are entitled
iyad
PostPosted: Sat Nov 03, 2007 5:57 pm    Post subject: Reply with quote
Mike
I do have the activation file .dct in the folder
iyad
PostPosted: Sat Nov 03, 2007 6:01 pm    Post subject: Reply with quote
Duckie
I only see Canary and no other maps there under manage maps. The name of the new map is Western and Central Europe
PostPosted: Sat Nov 03, 2007 6:09 pm    Post subject: Reply with quote
Can you write down/ post the full file name of the dct file? - Mike
Page 5 of 12
22.094 (25 Sep 24)
