Pocket GPS World :: View topic - Tomtom Navcore v7
Tomtom Navcore v7
BAZZA77
PostPosted: Fri Nov 02, 2007 10:43 am    Post subject: Tomtom Navcore v7 Reply with quote
Has anyone noticed that if you upgrade to tomtom navcore v7,when you update your tomtom through tomtom home.all your warnings are wiped for your speed cameras,and you have to reset them again
BAZZA77
PostPosted: Fri Nov 02, 2007 12:55 pm    Post subject: navcore v7 Reply with quote
just been having a mess with the totom,and its not updating though tomtom home that causing the problem.its using ogg files and the default sounds togther,there is a bug in navcore 7 that when you set a camera to use a default sound like polite 2 then try and set a different camera to use an ogg file it wont let you.if you set most off your cameras to you ogg file then try to do one with the default it wipes the lot off.
PostPosted: Sun Nov 04, 2007 9:08 pm    Post subject: Reply with quote
Nope... it's not that (or not JUST that...) Smile
I don't use any ogg files (even though I made a lot of them!) and my 720 still occasionally loses all its warnings. Although it seems to happen more often after I've done a lot of connecting o the PC (with or without Home), it has also done it when I've been away on holiday and not been near a computer.
I just can't get a handle on what causes it.
xda
PostPosted: Mon Nov 05, 2007 2:03 am    Post subject: Reply with quote
Only lost them the once, I'm using the .ogg file method. With full spoken warnings and warn only if on route.
The loss occurred after updating the map version from the out of the box version to the current one using TomTom Home.
I also have TomTom V6 Western Europe on the XDA Orbit with the same POI's but warn when on route deselected. That I use for camera warnings when I don't have a route planned on the Go720
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
22.101 (03 Oct 24)
