Pocket GPS World :: View topic - Where's me POIs - yikes
Neilj99
PostPosted: Thu Oct 25, 2007 10:46 pm    Post subject: Where's me POIs - yikes Reply with quote
I've tried both methods of downloading the POIs.
I've copied the zip contents over to the western europe folder.
Home shows the downloads on the device on the explore screen, however, when on the enable POI screen on the device, they are nowhere to be seen.
Why is this?
Neil
GO 910 ver 6.525
Border_Collie
PostPosted: Fri Oct 26, 2007 12:41 am    Post subject: Reply with quote
Did you remember to unzip the file and copy contents from the newly created folder?
Neilj99
PostPosted: Fri Oct 26, 2007 12:46 am    Post subject: Reply with quote
Sure did.
Border_Collie
PostPosted: Fri Oct 26, 2007 12:51 am    Post subject: Reply with quote
I've read other posts where it's recommended you don't use Home, so try copy and paste the files directly to the map folder you are using.
Neilj99
PostPosted: Fri Oct 26, 2007 12:57 am    Post subject: Reply with quote
Thats what I did. I merely remarked that the POIs appeared in the Home explore screen.
PostPosted: Fri Oct 26, 2007 1:33 am    Post subject: Reply with quote
have you gone over the 100 poi category limit?
anything over the limit will simply not show
Neilj99
PostPosted: Fri Oct 26, 2007 1:41 am    Post subject: Reply with quote
The only categories in the unit are the built-in 910 poi's and the latest complete zoned pocketgps cameras.
Oldboy
PostPosted: Fri Oct 26, 2007 6:59 am    Post subject: Reply with quote
Have you copied them into the right Map Folder?
Neilj99
PostPosted: Fri Oct 26, 2007 1:37 pm    Post subject: Reply with quote
Sure did.
Oldboy
PostPosted: Fri Oct 26, 2007 3:45 pm    Post subject: Reply with quote
Have you tried a Reset? It might work.
Neilj99
PostPosted: Fri Oct 26, 2007 5:10 pm    Post subject: Reply with quote
*hides head in embarrassment*
I double-checked what Home said was installed, and realised I also had the Tomtom specific cameras loaded for the *whole* of Europe (in addition to the PGPS cameras), not just the UK. I've removed all the other European cameras and the PGPS POIs popped into action.
Thanks for all your suggestions.
Neil
Oldboy
PostPosted: Fri Oct 26, 2007 6:14 pm    Post subject: Reply with quote
You're not the first, and I doubt whether you'll be the last. Smile
PostPosted: Sun Oct 28, 2007 9:20 pm    Post subject: Reply with quote
So to summarise....
Count the number of .ov2 files in your map folder, using Windows Explorer. IGNORE anything 'Home' tells you.
More than 100 .ov2 files = missing POIs.
