Posted: Fri Oct 26, 2007 10:44 am Post subject: POI's and Igo Maps
Hi all,
I used to have a medion navigator with with medion navigator 5. I now have a mio p350 pda runnig igo maps. I was wondering can i make certain poi's like asda, etc show up on the map, as I drive so i can just see the sign??? At the moment I have to search for a poi, but I want it to show them al on the screen, can this be done, and if so how?
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Fri Oct 26, 2007 2:55 pm Post subject:
I can't find any built in Asda stores so you will need this http://inetcom.hu/mick/igo/ where you drag and drop the .cse file into the programme and it transfers to a new group in My POI. I would like to point out this programe is BETA and after experimenting with some POI's, which transfered OK, I couldn't get rid of them without a hard reset and re-install.
Start iGO, tap on Map, tap on Menu (top right), tap on Quick (bottom centre) Tap on Manage POI. Choose My POI then Asa and choose to Show or Hide POI's.
Remember, the more POI's you have showing on screen can slow down the refresh rate of the mapping.
Posted: Fri Oct 26, 2007 4:06 pm Post subject:
DO I PASTE ALL THIS IN IGO/POI/SPEEDCAM FOLDER??? WHAT ABOUT THE PICTURE OF THE N FOR NETTO??? DO I DRAG THAT IN THERE AS WELL??
Use the iGOPOIExplorer programme and drag and drop the file to the left hand window and using the programme you can transfer the folder to iGO.
Once done, go to Quick - Manage POI's - My POI, tap on your new Group once, Netto?, to highlight it, then tap on Edit (centre of screen) and select an appropriate icon. Arrow back (three times) and tap on Menu.
Tap on POI - My POI and you should see your new Group.
The built in iGO POI icons appear to be embedded in the programme and I can find no way of adding/changing them.
Posted: Fri Oct 26, 2007 5:07 pm Post subject:
AM I STILL STUCK WITH THE ONLY ICONS IN THE IGOEXPLORER PROGRAM?
Yes, it seems so. I've looked in the various Data files and can find some icons, not the ones mentioned earlier, but the icons are in vertical strips, several on each, rather than being individual.
Is there any real need to have the Asda icons showing? I say this because you will still be able to set a route to one or add as a via.
